Question about Audiovox FPE1708 17 in. LCD TV
I have a 17 inch audiovox LCD that has power but the screen is dark, no picture. Need help as soon as possible
  • 4 more comments
  • ivan_rolle Aug 02, 2009
    I have a audiovox 17in lcd tv with power but no picture. I checked the inverter board but need more help in determing if the board if faulty.
    The audiovox lcd 17inch has no picture but the tv has power. The tv has an internal problem. I checked the inverter board. How do i know if the board is faulty.
    I have a audiovox 17 lcd tv, with power but the screen is dark with no picture. I checked the inverter board but need help to deetermined if the board is bad.
    I would have to check for hv out put. Thanks! This is the best advise i have gotton. I will let you know.
  • ivan_rolle Aug 03, 2009
    Thanks guy one of the inverter SMPS transformer was defective. Will try and get a new inverter board from shop jimmy.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to Fixya,
Offhand, without a schematic diagram or a service manual, checking the inverter would be relatively difficult. A few things to consider:
  • the inverter is supplied with DC voltage;
  • as the name implies, its function is to invert the DC and produce high voltage, high frequency ACV to in turn supply the CCF lamps (cold cathode florescent);
  • if only a multitester is available (preferably an analog needle type meter), test for the presence of this high frequency, high voltage at the output of the inverter;
  • the output would at the SMPS style mini transformer;
  • depending on the model/version, there could be 1 or 2 of this transformers;
  • since this is high voltage, safety precautions must be kept in mind when performing tests on live equipment;
  • it must be mentioned that some inverters have a soft off trigger for video muting;
  • in some instances, fault could be as simple as a cold solder or a dried / leaked capacitor.
Good luck and thank you for asking FixYa.
Posted on Aug 02, 2009
  • Louie  Role
    Louie Role Aug 02, 2009
    Is there any high voltage output?
  • Louie  Role
    Louie Role Aug 03, 2009
    Again, pls be careful when checking for the presence / absence of the HV output.  In some versions, there would be some sort of shielding that is over the HV area.
  • 32,281 Answers
Plug another monitor to the computer to determine it the video card is OK, If you see a normal image then the fault is the 17" LCD.
If you view the LCD at a sharp angle and you can see a dim image the the CCFL lamp or inverter in the LCD is faulty.
For spares, service and DIY info. check out LCD Parts WEB site.
Use this link:-
www.lcdparts.net
Posted on Aug 03, 2009
  • 4,924 Answers
When the screen is dark for no reason usually the cable is to blame ...just double check the cable to be well plugged also you may change it ..maybe its faulty ...install the driver cause it might be some issues of compatibility involved..if you know it that it worked well on this system ..it may be something related with the image driver ( video card driver) you might been messing around with the color registry from control panel and now it came up black after restart .. in this case there is almost nothing that you can do ..but restore it to an earlier point after boot from CD ..or try to reinstall the whole pc ...by the way ,,,this is an idea boot from cd ..to see if you have any image on it ..just like you reinstall it ...
you can also ..try to see from its settings maybe its messed from the manual settings on it ...just press auto set if it has such thing
let me know how it came out ...
  • Catalin Turcu
    Catalin Turcu Aug 02, 2009
    sorry I was under the impression that you were talking' about a pc.monitor....if its about a lcd tv ..I can not help ..
  • Audiovox Master
  • 19,396 Answers
To start check the video cable, and test the monitornconnecting it to a different computer if possible.
Try also unplugging the monitor from power for thirty minutes, that will reset the internal circuits.
If still no luck, then there is an internal fault.
If there is no picture, and the unit does not appear to be in standby , or with the led blinking (protection), then the problem is usually the inverter board.
Sometimes when is the inverter you can see a faint picture by pointing a torchlight near to the display with a 45 degree angle.
If the led is blinking, or unit stays in standby , then there is a internal fault.
In that case it can also be the inverter, but PSU and controller board must be tested before replacing the inverter.
You can find parts at: Audiovox Parts | ShopJimmy.
Regards
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
St2410b no display
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/dell-n26397-lcd-inverter-p-5754.html
Aug 22, 2013 | Dell E173FP 17" LCD Flat Panel Monitor
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
Jan 20, 2011 | Computers & Internet
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
Feb 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
I have a Dell 17" flat screen ultrasharp monitor. It suddenly went dark and will not power up. Can it be repaired?
With the dropping price of monitors today; can get a good 22 inch lcd for less than $200 in most stores, it would probably cost more to have the old monitor repaired than just replace with a new monitor. Hope this helps.
Jul 17, 2009 | Dell E173FP 17" LCD Monitor
Just a really dark screen on all functions
If you are still under warranty try calling audiovox customer support at this telephone number 1-800-645-4994. Give them the model number of you dvd player and tell them the problem you are having with the dark screen. If you are not under warranty, You can still call them and ask them where to get service for bad power inverter or a bad back light problem. If they cannot help you you can go to this website http://www.lcdparts.net/Default.aspx They do all kinds of LCD repairs and also have a technical help telephone number. 1-877-870-0581. Give them a call and tell them the name of your dvd player and the model number and see if they can help you get repair service for it. I hope this information will help you with your problem.
May 30, 2009 | Audiovox D1210 Portable DVD Player with...
Samsung LCD Question
The model is a LN-S4041D. A 40 inch LCD. I can send you a photo but I can't get the file size small enough to post
Feb 09, 2008 | Televison & Video
Sony Cyber-shot DSC-N1 8.1 Megapixel
http://www.dcresource.com/reviews/sony/dsc_n1-review/ Hi there, just fixed mine. Had the same problem. Click on link above. Leisa1
Jan 20, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Audiovox FPE1708 17 in. LCD TV Logo
61 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
