Question about Toshiba (K000680310) for Satellite 1605CDS, 1625CDT, 1675CDS, 1695CDT
We have a toshiba Sattelite A45-140. Hard drive problem
Yes, Hi. we get a disk read error, and cannot turn computer on. I spoke with someone at Toshiba and they recommend taking it to adealer/repair to get a new hard drive,
Can I do that myself?
  • 136 Answers
It is not that hard to remove the drive, though, if you are prone to have leftover screws when you take devices apart, you should get help. And before you part with your cash, make sure that the hard disks available are compatble with your laptop, since I have difficulties finding non SATA (IDE) disks for my old 5005.
Posted on Oct 15, 2008
Toshiba portege 3500 tablet saya tidak bisa booting lewat external cd room .. yang ada di layar monitor terbaca : intel(R) boot agent version 4.1.06 copy right (C) 1997-2002, intel...
It means that the BIOS cannot find a disk to boot.
Make sure you selected the hard drive in the boot settings of your BIOS
Remove all external DVD drives or floppy drives or ethernet cables
If you get an error message, you should start troubleshooting your hard drive.
Feb 27, 2011 | Toshiba Portege 3500 Tablet PC
I ave a toshiba m200 that is taking to long to operate and when it does i stuck and refuse to function in any way!! i have no idea what is the problem and am trying to retrieve my work and upload it in a...
Hi,it is possible that the resultant cause the problem is your hard drive(caused by the hard disk failing to be READ from or be WRITTEN to,in this case be READ from),or one of your Memory modules is failing,so first of all try swapping or switching the RAM modules from one slot to the next,one at a time,if system is still slow,take out your hard disk,get a converter,slave hard disk to another system copy your files out and get a new Hard disk.
Jan 04, 2011 | Toshiba Portege M200 Tablet PC
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
I changed the hard drive in my m400 and i doesnt load windows says somthing about a dianostic disc! what do I do.
You haven't said whether you installed Windows from the original factory discs which came with the laptop. If you haven't done that yet, open the cd tray and put the 1st disc in. Shut down the laptop. Reboot the laptop and it should boot off the disc and ask you if you want to "format" the hard drive. At this point you should be able to follow the on screen instructions until everything is loaded, including all hardware drivers. Any other software you had on your old drive will need to be reinstalled on this drive from the disc. If the software is old you may want to go to the appropriate website for the driver and download the newest version. That should complete your install. Let me know if you need more help.
Thanks for using FixYa and the generous rating.
Mar 06, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
Computer shuts down as soon as i boot it. it says
Sorry friend, Windows has died on you. You need to reinstall it.
Nov 01, 2009 | Toshiba Portege M400-S5032 Tablet PC
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Oct 22, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Replace hard drive but can't load tablet operating system
Do you have the system restore disks for your tablet? Once you have restored windows then you need to use the second disk to load all the drivers
Mar 23, 2009 | Compaq tc4200 Tablet PC
Disk error
Does the laptop have a usable cd/dvd rom drive?
May 13, 2008 | Toshiba Portege 3505 Tablet PC
Portege 3500
You can obtain the Recovery disk from Toshiba. Toshiba hotline number 1-800-457-7777 (US) 0844 800 6020 (UK). You need to provide your computer's part number correct to get the matching recovery disk. Usually they charges $39.95 including shipping to your address in US. Alternately you can go to
Good Luck
Dec 29, 2007 | Toshiba Portege 3500 Tablet PC
Make sure sound is comming from ur hard-drive.If it show possible reasons can be.... 1. Your hard-drive is not screw-up proerly. It is unbalanced. 2. Take care you hard-disk safely it may cresh soon.For long age of your hard-disk shut down your pc properly.
Sep 10, 2007 | Toshiba Portege M205-S810 Tablet PC
Tablets & eReaders Logo
114 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
