Question about Gemini XL-500 Turntable
My Gemini TT02 did not produce a hum for the first few months but now is so loud it's unusable. I first used it with a replacement sound cable, without grounding(as I needed a longer one), but since the hum started have tried it with the original one, taping the other end to the bottom of my amp, without any success. I am considering replacing with shielded cables (again non-earthed because i am yet to run into these), but could it be the mains cable that needs replacing, which is permanently attached...? I really cannot do anything too complicated, such as grounding under the floorboards or in the garden as I lack the expertise... Any suggestions?
    Genius:
  • 1,114 Answers
Typically, one would run a single wire, 18 or 20 gauge will work, from the turntable motor housing to the amp chassis. I know the older amps have a ground screw on them,, but any chassis screw will work.
Posted on Aug 02, 2009
Infinity tss 750 sub-woofer when powered on immediately pulls speaker in and has loud humming. no inputs hooked up, only plugged in to ac power source.
The loud humming is the sound of AC mains - clearly your amplifier is receiving an input from somewhere and possibly into the front end.
The hum could be induced by radiated energy from nearby unshielded equipment, it could be the result of an accidental hum-loop or could be because the amplifier power supply has a fault.
It is usual practice with amplifier construction to ensure unused inputs are shorted to ground by switching or by additional contacts and wiring at the input sockets. High gain high impedance inputs can cause a great deal of unwanted noise if they are not shorted.
I suggest you read the instruction manual and perhaps Google a few hints and tips about amplifiers and stuff.
Mar 28, 2016 | Infinity Audio Players & Recorders
Gemini tt02 needles
Hi, with your thumb and index finger grip the stylus at the front. Pull down and then forward. Cheers john. Stylus City
Mar 01, 2014 | Audio Players & Recorders
Bose Wave Radio pops, loud hum that fades
Power supply capacitors have dried out and need to be replaced.
Sep 03, 2017 | Bose Wave Radio
Hi, we have a humming sound that is really loud,
Yes, its fan noise and you need to replace noisy fan.
Let me know exact model of your Sony TV and need to know what fan is producing noise to provide you part number and parts shop info to buy that fan.
Jul 31, 2009 | Sony Grand WEGA KF-50WE620 Television
Reel to reel tape recorder hum
Try replacing the Electrolytic Capacitor(s) on the power supply. They will be big value anywhere between 2,000UF and 6800UF. But capacitors of this type are notorious for causing hum, any on the deck could do it!
Apr 05, 2009 | Audio Players & Recorders
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
Gemini tt02 no sound!
phono \line switch the right way maybe.have you got signal on the mixer from dodgy deck
Aug 20, 2008 | Philips gemini TT-02 Turntable
Sunfire Mk II hum (different from greekboy post)
I had this issue a few years ago and the power cable from one of the inner terminals had come loose. It was still touching but whenever the sub would really pound it would jump off the connection and then reconnect causing it to hum. It was the most annoying thing ever so I finally pulled off the amp plate (super easy) and you could clearly see the loose wire. I had to use a good soldering iron to put it back on since it's a pretty fat wire. If you're not under warranty anymore then pop the back off and see if that's the issue.
-Dylan
Aug 17, 2008 | Sunfire True Sub MK II Subwoofer
Gemini XL-500 Turntable Logo
201 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
sean tan
Level 1 Expert
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
