Can not get belkin router to hook up to comcast internet
  • 404 Answers
Hello. I will be more than glad to assist u on this concern.. ur using a comcast cable modem.. first.. connect ur computer directly to the router and perform a mac clone on the router. this will clone the mac address of ur network interface card and then use the dynamic settings
Posted on Aug 08, 2009
  • 17 Answers
SOURCE: Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Posted on Nov 09, 2007
  • 173 Answers
SOURCE: belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Posted on Jan 09, 2008
nsindian
  • 137 Answers
SOURCE: 2 wire router and Comcast
Cable from modem gets inserted into router port named WAN/Internet
from router you should have a cable going into back computer ethernet port.
once inserted, input router IP address into an address bar (IE or My Computer) eg. 192.168.1.1 --- to find out what your router I is:
Start > Run > cmd > ipconfig /all --- router ip would be listed as Default Gateway or DHCP server
Once logged into router, go to Properties page of router config and perform a Release and Renew of router's ip
Posted on Jun 30, 2008
mspcrepair
  • 169 Answers
SOURCE: arimex comcast router won't talk to belkin wireless g plus mimo router
Comcast has a little known "trick" that they use when setting up users. Here's how it works:
When Comcast first comes to setup your new cable modem service, they insist on connecting it to your computer and "testing" it. Most people think nothing of it, and that it's good customer service ...truth be told, what they are doing is attaching your computer's MAC address to that cable modem, so that you cannot create a wireless network. This is because they want you to pay them $150 to do this for you.
In this situation, since the modem is a modem/wireless router in one, my guess is that the MAC address on your machine now does not match the MAC address on the new router, which is what Comcast has stored in their database(s).
Try this: on your computer (while connected to the modem), perform a release on your IP address (start, run, cmd, then type "ipconfig /release"). Disconnect the ethernet cable from the computer. Turn computer off completely. Hold down the reset button on the cable modem until it performs a reset. Once it's back up and running, boot up your computer with the cable back in the ethernet port.
The cable modem should assign a new address to your computer. However, that may or may not work ...this is an easy workaround with a Linksys router, but not necessarily with the all-in-one devices.
Worst case scenario: contact Comcast and notify them that the new modem is not recognizing your computer's MAC address and that it needs to be updated in their system. They will scan your computer (through the telnet interface on your modem) and get your computer's MAC address, then (hopefully) make the necessary changes on their end.
After that, everything should work flawlessly. If not, insist on a Comcast tech to "fix" the service that you are paying for.
Good luck - hope this helps :)
Posted on Sep 29, 2008
  • 226 Answers
SOURCE: My Belkin N1 Wireless Router won't read my cable
you should be about to loginto the router interface and set DHCP and that should work for comcast
Posted on Jul 20, 2009
Need passwword for belkin wireless router
By default, Belkin routers do not have a password,just click on Submit to log in..But you should check check your Belkin router setup documents.
If you forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
Sep 11, 2012 | Belkin (F5D7230-4) Router (587009)
I have Comcast Modem hooked to Belkin G54 Router my HP runs great even through router but my Systemax cant keep a connection
Turn off the HP and see if anything changes - you might have a bandwidth problem with Comcast.
Dec 14, 2010 | Belkin Wireless G Router
Comcast unhooked it and i dont know how to hook it back up
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
Belking wireless router can't see my comcast cable modem
then login to router setup page with 192.168.2.1 type this one in the address bar of ur browser
then u will see router setup utility
then click on the restore factory settings on the left hand side under UTILITIES
it will ask u for password leave it blank and click on submit
then click on restore factory default
once it is completed then on the rite top corner u can find the internet status --- it has to be connected or else
u can unplug the modem and routers power cord and wait for 1 min
the plug the powercord of the modem first wait for few seconds till the light are stable on the modem then plug the powercord of the router
then ur internet light should be solid on the router
Dec 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Belkin G wireless Router
Do you have an all-in-one router from Comcast? For example, do you have the cable (RF) line and your PC plugged into the Comcast router? If so, unplug your PC from the Comcast router and connect the Internet port of the Belkin to the ethernet port on the Comcast router. Then plug your PC into the LAN port on your Belkin.
[PC] ---> [Belkin] ---> [Comcast] ---> Internet
Once you have connected your boxes as displayed above, you will need to power everything off and bring up the boxes in the following order:
Comcast (wait 60 seconds)
Belkin (wait 60 seconds)
PC
If you cannot get out to the internet, momentarily press the reset button on the back of the Comcast box. Comcast routers are weird. A poweroff should reset the router but I have seen a few times where nothing works until the reset button is pressed (this is also recommended by Comcast).
I hope this helps.
Dave Grannas
Jan 26, 2009 | Belkin (F5D7230-4) Router (587009)
How do I access my Belkin N Router's settings?
open internet explorer and type 192.168.2.1 and the will get u to the belkin router page and then click on mac address control and then type ur password to get in to the router and it will take u to all the mac address u have allowed or denyed
Dec 28, 2008 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
475 people viewed this question
David Payne
David Payne
