Question about Sony MDR-XD200 Consumer Headphones
Headphone wire cut ,it is not working
Do u mean the white cottong inside each of th e sires needs to be taken out? and then i should join the iwre to each colours?:S so then can i cut the cottons off?
  • Michial Gueffroy May 11, 2010
    The cotton is a type of separation and insulation between wires. You remove as much as you need to. You also have to very carefully scrape the color off the wire to expose bare wire to get a good solder joint. Remember to match colors.
    President:
  • 1,137 Answers
The cotton is a type of insulation remove as much as you need to. You also have to carefully scrape the color off each wire to expose bare wire to get a good solder joint. Remember to match the colors when resoldering.
Posted on Aug 03, 2009
What number is the reverse light fuse on my 2005 astra
Most likely cause is the switch on these cars ,join the iwres together to the switch and see if the lights work before you pull your hair out getting too technical .And no the switch cannot be taken apart and the contacts cleaned
Nov 04, 2014 | Holden Astra Cars & Trucks
Tip
Replacing a dodgy plug/cable on headphones.
I have noticed a few people posting on the fact that their headphones are cutting out, or they have lost sound, or damaged the jack plug that goes in headphone sockets of amps, or I-Pods, or Mp3 players.
So if you have this problem here's what to do. First you must have a soldering iron, no greater than 25 watts, with a smaller tip as possible. A desoldering tool might come in useful too.
The first thing to do is determine where the damaged area is. This can be done with ease by plugging the headphones into a working source and flexing the cable all over (in stages) till you find where the break is.
I'm splitting the break areas into 3 sections which will help you determine the best course of action. 1: A break near the plug or the plug itself. 2: In the middle. 3: Near the headphones themselves.
Break Area 1: The most common area as the plug gets most abuse. The plugs are sealed and are not serviceable, so they have to be cut off and a new one fitted. I recommend (if it is just the plug that has gone) to cut it off about 10cm before the end of the plug body. This will take out any weak section of the cable due to bending. If the break is further away from the plug, allow some space to clear the damaged area.
A replacement plug. You should be able to get a replacement plug from your local electrical parts shop. They come in two main sizes 3.5mm and 6.35mm (1/4). Most headphones are fitted with a 3.5mm now. You can get adapters for both sizes. It is easy to solder to the larger size, but if you are fitting a new plug to go in an I-Pod etc, I would advise you use the 3.5mm. Jack plugs come in different types. Some have bends in them, you can get them in gold, also with metal bodies. The latter would be best if you have a habit of standing on the plug! Make certain you get a STEREO plug too!
A 3.5mm stereo jack plug.
28c9160.jpgFitting a new plug.
After you cut the old plug off, don't bare the wires back, but put the body of the new plug on the remaining cable. Then strip the wires back.
They should look somewhat like this:
3336b90.jpgThe colors may change with different makers.
The - wires are earth and the + wires are the channels. Never confuse the two.
Inside the plug
79bf156.jpgConnection is simple attach the right + wire to the right channel flange. Pass it through the hole, then do the same to the left. You don't need a large area of wire exposed when you strip it back, as the thick black cable has to be gripped by the Ground flange at the end.
The earth or - wires should all be group together and passed into the hole on the ground flange.
Make certain that the + wires L&R don't touch each other or the - wire ground. You can now solder them on. I find that applying a bit of spit to the wires helps the solder go on better! Again don't let the solder join the connections to each other.
At this point it's a good idea to test the plug by fitting it in a working device without putting the body over the plug.
If the channels are there, but it sounds spaced out or tinny, the - wires are not making a connection to the ground. If the right appears on the wrong side then reverse them (it won't have caused any damage).
If the connections are good slide the body over and the job is done.
2: Break in the middle.
Again cut off and fitt a new plug as above.
If the cable needs to be longer you can get one of these extension cables:
1da0e5b.jpg3: Break near the headphones.
This is the most tricky of the lot. It generally means a new cable. If you can't find one in your local parts shop, I suggest you get one of the above extension cables and cut off the female socket.
Replacing the cable will be more tricky if the wire is split in two (outside). This will mean you have to go in both "cans" to fit the wire.
There's no easy way to get inside the cans, but you will need to remove the ear pad(s) on most models. You might have to use some force to do it too! If you encounter foam next peel it off, again you might have to rip it off! Don't worry you should be able to glue it back with some Bostick white glue afterwards!
Hopefully you should now see some access screws.
It might look a bit like this inside:
ce41201.jpgMake a note of the + connection, before you unsolder the wire. Unsolder it carefully you don't want to disconect the wire that goes inside the speaker (you might need a desoldering tool for this). Don't short the + & - terminals of the speaker together when you solder the new wires on.
PS If you need to replace the above type of speaker you will find it is glued in at that black ring.
DAMAGE TO THE HEADPHONES THEMSELVES
Some people have reported that the headphone case has broken or snapped, but they still work. So if you can't get hold of a parts to replace the broken bits and are more bothered by the sound quality then the look of the things, you can use section 3 to replace the headshell completely. All you need to do is find a cheap pair of headphones with the same size speakers as your current ones and take out the speakers and fit yours in the new cases. As I say they might not look as good, but they will sound the same!
Two final notes- if you have lost a channel and can't find out where the break is, the thing to do first in change the plug. If that doesn't work change the whole cable, but try a 1.5 volt battery accross the speaker terminals for a split second (it should pop if working).
Much of the above will NOT apply to the wireless or other forms of special headphones.
For those needing to replace earpads I recommend this site:
http://www.jntworld.com/catalog/index.php?cPath=21_1002cy=USD
Jnt World also have plugs and cables for headphones.
If I have sent you to this page and the above link takes you to a sign in screen or it doesn't work please let me know. And I will correct the problem.
Grubhead.
on Apr 13, 2010 | Audio Players & Recorders
My headphone wire was cut into two parts how do I fix it
Just strip the insulation back to reveal the wires, there should be 3 wires, one for the left headphone, one for the right headphone and a shield wire.
join the wires that have the same colors (solder each wire together) wrap each wire with insulation tape so they do not short against each other and then bind the whole lot together.
You headphones should work again.
Apr 04, 2012 | Dell Computers & Internet
I stood on the wire when i was going up stairs and then i tried playing music through them but they wont work
Its pretty clear from your explanation that the internal wire inside the external cable must have cut. So if you can do it yourself, try to locate the exact point wher it cut, get a blade or something to cut it open. Locate the point, take off the bad side. Then apply the blade on the internal wires, smooth to make sure you can clearly see the copper, then join back (colour- colour). Get a cellotape to wrap each of them to make sure they dont bridge. Then finally cover everything together to have one single straight wire and there you go. But if you cannot do this, then you need to give it to a repairer. Goodluck.
Apr 26, 2011 | Skull Candy Audio Players & Recorders
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
Left earbud completely silent.
Hi,what makes the left hear completely silent it because the wire inside the left side ear bud might have cut and it's not contacting with the speaker inside the ear bud.
What you will do is this, open the left ear bud that is not working, check if the connection is not properly fix. Also after checking if the wires are intact, if the wires inside are intact with no trace of cut inside,that means that the speaker inside is damaged and will need to be replaced..
If you can't do it your self, I would advice you contact a skilled personnel for help.
Thanks for using fixya....
Oct 21, 2010 | Shure (E2G) Consumer Headphones
Headphone wire cut
Carefully strip out the cotton strings I think this is causing bad connections with your joints and join the bare wires red to red green to green and the copper which is the earth to copper and this should work
Aug 02, 2009 | Sony MDR-XD200 Consumer Headphones
Mark 1 pajero
hi lee,
what you are looking for is a normally close relay...it is about an inch by inch square and it would cut off the wire from your ingintion switch to the starter. that is the imobiliser relay.
try to trace the wire from your ignition switch going to the starter. maybe you can see where they cut the wire.
tnx,
drcool
Aug 26, 2008 | 1991 Mitsubishi Mighty Max
Sony MDR-XD200 Consumer Headphones Logo
200 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
