Question about Nokia 6630 Cellular Phone
At first i got a small scratch on the screen and i
At first i had a small scratch on the screen and i don't know how i got it and then it started growing bigger and bigger and now its rely big!
  • 374 Answers
That's the screen that's gone kaput/bad.Need a new screen or a new mobile...rather coz screen for some mobiles are quite expensive. That's one problem that you cannot repair.
Posted on Aug 02, 2009
How to clean screen
I dont know which type you have but here is how to clean either:
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don't ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
LCD monitors are often called flat panel monitors because they are flat and thin. These are the types of screens that are used in most laptop computers, and they are also becoming very popular for desktop computers. LCD screens are softer than CRT glass screens, so they require some extra tender loving care. Keep your fingers and sharp objects away from these screens since they are susceptible to damage and scratches.
Use a soft dry cotton cloth to remove fingerprints and smudges from the screen. If this does not completely remove the dirt and splotches, use a small amount of isopropyl alcohol on the cleaning cloth that has been dampened with water. (A small amount of vinegar can be substituted for the isopropyl alcohol.) Again, spray the liquid on the cloth and never directly onto the screen. Do not use paper towels on an LCD screen as they can scratch the screen. Never use ammonia, ammonia-based cleaners, or strong cleaners which can cause the surface to yellow and become brittle.
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don't pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Nov 01, 2012 | AOC e943Fwsk 18.5" Widescreen LED Monitor
How do I fix a scratch on an LCD screen? Its not a small scratch. I can see a small white dot through it. Is it possible to fix? Is there a risk of radiation?
There is no risk of radiation through an LCD. Only blinding light that can give you a headache. (I tried using a CCFL as a desk lamp. Headache follows, and despite what people keep telling me, I don't think I look like was born at Chernobyl.) As for the scratch, you must first come to terms that your monitor will never again be perfect, and then decide what is the best course of action for yourself and your skills with the understanding that this will not be easy and it will take quite some time. Personally, this is what I would do. Use something to very carefully blot the bright spot, I would probably use a tiny bit of ink on the tip of a sharpened toothpick. (Apply at a bit of an angle parallel to the scratch to avoid pressure points and stray ink.) It is better to have small dark spot on the screen than a bright one. Next, turn off then unplug the monitor and lay it down as flat as possible. Then, with a very soft touch, clean the entire screen with a gentle sanitary wipe. No strong or abrasive cleaners. If t.p. is what you have than that is what you have. If the wipe is dry, put just enough water on it to make it just damp enough to clean the surface. Take a damp q-tip and dip it in some ash then brush off any rough particles. Gently rub the ashen q-tip along the scratch lengthwise using as little pressure as possible. Rubbing across the scratch may make things faster, but will make the blemish larger, trust me. Repeat with the ashen q-tip until you are satisfied that the edges of the scratch are no longer rough. Very carefully with a barely damp fresh wipe, remove the rubbing's from the screen. Here comes the hard part. What to use to help close the gap, and gloss the finish. Nothing that I have seen or tried is perfect. My fist choice would be to leave it and thank whoever you do or don't pray to that it still works. If this is not acceptable, then if possible, get or debo an anti-dust or anti-glare or privacy screen for the monitor. If this is not possible, but you have access to a water based clear acrylic pen with a satin finish, you could go with that. Do not use gloss or high gloss, shiny things attract attention. Whatever you use to cover the scratch, make sure it is water based, because the solvents in others will tarnish or melt the plastic overlay of the LCD. Another possibility is, if you know someone in the area who paints, perhaps you could get a little water based clear coat with a satin finish, and use a tiny bit of sponge to apply it to the screen. Using even a small brush will leave brush strokes, but if that is what you have, then that is what you have. Best of luck to you, I hope it works out. :)
Sep 19, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
My Xbox 360 disc is scratched and I can't play it.HELP!!!!!!!!!!!!!(How do I fix it???)
Try fogging it with your breath and wipe the disc from the INSIDE circle and straight OUT to the outside rim of it. Don't rub all around the disc; it'll just ruin it. Start from the inside, wipe straight out. Alternatively, you could use a glasses cleaning polishing cloth. Again, wipe from the inside out. Then add some glass cleaner onto it and (once again) wipe it gently. If you have any Carnauba car wax, use a small amount on there; it'll fill in the scratches that are there. For the last time, wipe from the inside out. It's a lot, I know, but I hope it works for you.
Jun 22, 2011 | Health & Beauty
Small crack in screen
As the screen has a scratch, there is no option using which we can rectify this problem otherthan changing the screen from the Service centre..
Jul 07, 2009 | T-Mobile BlackBerry 7105t Cellular Phone
Scratch on plasma screen
You should be able to make the scratch become invisible using a white eraser. A pink one will work, but the white one works better. Just simply erase the scratch, it may take awhile, but your basically buffing the surface down even again making the scratch un-noticeable.
Jun 21, 2009 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Scratch on nikon s210's lcd screen
I think it probably is but I know of an item I heard about from a friend called Displex. He had a PSP with lots of tiny minor scratches and he used it with success. You might want to give that a try.
Feb 08, 2009 | ViewSonic VA712 17" LCD Monitor
Help!
There is a thin plastic lens that covers the main LCD. Most commonly Oils from your skin can work into the phone and lay between the lens and the screen.
With your fingernail, you can gently work an edge of the lens till you can get under it and remove it. You can use a knife or tiny screwdriver. Once it starts to lift, it will come off easily, it is only held in place by a thin layer of adhesive around the edge.
Take a lint free cloth and wipe the screen (CAREFULLY) and the back side of the lens. Then just lay the lens back in and you should be taken care of.
If it is anything else, like a dark spot in the screen itself, or adhesive around the edge of the lens, let me know. I can tell you exactly what you would need and where to get the parts.
Aug 21, 2008 | Motorola Mobility RAZR V3
Cleaning monitor
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don’t ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don’t pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Jan 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Removal of Scratches on TV Screen
you can try toothpaste. use on the scratched areas in a circular motion for around 5 minutes. This can reduce, and remove scratches from plastic, and even glass. Wipe of with a clean soft fabric or tissue paper lightly moistened.
Another solution is scratch-out. Which is used to repair spiderweb scratches in the clearcoat on automobiles. This is a polymer coating on cars. Your screen is also a polymer. follow the directions carefully, and don't get too aggressive with it. If it doesn't work, what you lost?
The poster above is obviously inexperienced with this type of thing.
Dec 26, 2006 | LG 30FZ4D TV
Nokia 6630 Cellular Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
