Question about Toshiba Satellite A135-S2276 Notebook
A135-S2276 does not turn on
I have a Toshiba A135-S2276, only AC power light is on and no other lights. Laptop does not turn on. Laptop is < 8 months running Ubuntu Linux. I am thinking internal power supply. Any suggestions?
  • NewToLaptops Nov 26, 2007
    Hi Poohawk
    I pulled out the one memory card and re-set it. Needed to push the power button for 10+ seconds, and she came back! Thanks for your help!
  • mtrudeau7 Nov 27, 2007
    My laptop was shut down normally a few days ago. Now when I went to turn it on it appeared dead. Plugged it in, thinking it was a battery or power issue with no luck. Don't know where to go from here.
  • 324 Answers
Try removing the memory and hard drive. Replace just one memory module and see if it comes up. If it does, replace the hard drive and bring it up. If that works, try replacing the other memory module.
If it doesn't, get back to me for more ideas.
Posted on Nov 26, 2007
  • Ron Roske Nov 26, 2007
    Good morning, NewToLaptops!
    I'm happy to have been of service and glad to hear that you are up and running again!
    Since this answered your question, is there any chance that I could get you to change the rating to "FixYa"? It would help a lot, if you could.
    Thanks, and have a super day!
Power light comes on,but no video,fan runs for a few seconds then turns off does not boot,what's up?
First, remove the battery and unplug the ac adapter then press and hold down the power button for 10 seconds to drain power from the laptop. Remove any external usb device or flash cards inserted in the computer.
Set aside the battery for the meantime and connect the ac adapter. Now turn the laptop on and see if it powers up. If it powers up, then you resolved the issue but if it doesn't, then you might have an LCD or Motherboard failure
Jun 23, 2010 | Toshiba Satellite A135-S2276 Notebook
Charge isn't consistent. Orange light flashes instead of remaining on when charging.
Are you using the original ac power adapter, or one that is designed for use with your model to ensure that it is fitting tightly where it plugs into the laptop at the dc jack?
If so, the dc jack could be broken, which could prevent the battery from charging properly, resulting in the flashing amber light, which is indicating that the battery is still low and needs recharging.
Another possibility is that the battery is defective, but the more likely problem is the dc jack since it is such a common problem.
You can find a replacement dc jack here.
Good luck, please let me know if it helps.
May 08, 2010 | Toshiba Satellite A135-S2276 Notebook
The pc not turn on, no power
It might be an issue with the adapter, the battery or the AC jack on the motherboard. First up see if your AC adapter's power LED comes on when plugged into a power source. If it does, then check if the Lights at the front of the laptop indicate that the adpater is plugged in. If they light up then it means that the laptop's battery is faulty and needs to be replaced. If the lights dont light up then it means that the AC adapter jack on the laptop has bad solder joints and/or damaged. It is located at the underside of the motherboard where the AC adapter is plugged in. You will need to take the laptop apart and re-solder/replace the jack.
Let me know if you need more help,
Jan 05, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba A135-S2276 Black screen,only lights on front of laptop that are on are the power and battery light,fan work.i can here hard drive turning,DVD Driver light stays lit and will not open,Ive read...
i have encountered this problem before on many laptops and sometimes your monitor can just go bad or a piece of bad hardware in your laptop but in my case most of these problems are the monitor going bad. how old is this laptop
Nov 20, 2009 | Toshiba Satellite A135-S2276 Notebook
Where I can download drivers for xp+---++++++++++++++++++++++++++
Dear first of all you will have to register on it and then login and now go on to this link and download your required driver free
dear just click on this link and download driver for free
click on this link and find your driver and then download free
go on this link and download your required driver free
Good Luck
Oct 02, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a130/a135 series. I connect to
check the power cord to the laptop in the back wiggle it. check the lights. if they come on and go off with you giggling the power cord. the ac input socket may be broken. you may have to wedge it in one spot to get the two lights to come on let it sit there a while 20 min to charge battery some then turn on laptop.
Jun 23, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba Sattelite a135-s2276 turn on fan working but no display
I think some cooling devices on your laptop stopped working which might have lead to Motherboard problem due to heating.
Jun 22, 2009 | Toshiba Satellite A135-S2276 Notebook
Need a password...
Found these instructions on another website...
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Hope this helps
Aug 18, 2008 | Toshiba Satellite A135-S2276 Notebook
Laptop won't turn on
Unplug the computer from the adapter and then take the battery out. Put the battery back in. Put the adapter back into the computer. Enjoy computer.
Apr 13, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276... went in sleep mode.
Try pressing power button once. Does Windows logon screen come up?
Jan 13, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
154 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
