Question about Mtd FASTATTACH MANUAL SLEEVE HITCH
MTD Yardman HE4160 - Drive belt tensioner spring
My HE4160 just stopped yesterday, as I look under it i notice the problem is the drive belt from front to back has popped off. I have refitted, but there is a tensioner pulley in the center with a spring hanging down. I have no manual and cant see where to re-attach the tensioner spring. can anyone help?
2 Suggested Answers
  • 45 Answers
SOURCE: My MTD Yardman HE4160 just stopped yesterday
You can start by getting a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
The above web site also has a "parts finder" that gives detailed drawings for each model.
If you look around under the mower, you should be able to find the hole, or bracket where the spring was hooked. (look for rub marks, or scratches)
If the spring just fell off for no apparent reason, it may have been connected to a bracket that broke off (rust, vibration, etc) It is usually easier to make a new bracket then to try finding a replacement.
Posted on Aug 14, 2009
Battery light is on, hard to steer
The water is the ice that went underneath and no doubt knocked off the serpentine belt of fan belt to you and me old school fanatics ,take it to your local garage to have the belt refitted
Jan 05, 2014 | 1996 Ford Explorer
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
Kia sedona instructions to replace serpintene belt
Hi, Here is the procedure for a 2002 KIA Sedona 2.9, Engine code KJ. I I can not guarantee the followingprocedure is exactly the same as your car.
Warnings and recommendations Unless otherwise advised by the manufacturer, the following procedures are recommended: Always fit a new timing belt after removal Check the tensioner and idler pulleys; renew if necessary Never turn the engine in the direction opposite to that of normal operation Check the belt(s) for cracks, fraying, wear and oil contamination Note: The engine must be cold before timing belt adjustment Note: Avoid bending, torsion or traction General Before disconnecting the battery cable, check the audio system security code kj_t_dba_uk_6.jpg
Always check the timing marks before timing belt removal Removal Disconnect the battery Remove the radiator upper hose Remove the fuel filter unit Note: Do not disconnect the hoses carniv_j3tci_t_dba_uk_3.gif
Remove the bracket Remove the right front wheel Remove the air-conditioning drive belt Remove the ancillary drive belt Remove the ancillary drive belt tensioner Remove the coolant pump pulley Remove the crankshaft pulley Remove the timing cover(s) kj_t_dba_uk_6.jpg
Remove the tensioner Remove the timing belt Check the gearwheels, tensioner and idler pulley(s) for damage and wear Renew if necessary Installation kj_t_dba_uk_6.jpg
Align the marks on the tensioner Tighten the tensioner (23.5 Nm) Rotate the engine 2 rotations by hand kj_t_dba_uk_6.jpg
Check the tensioner Repeat the procedure if required Refit the timing covers Refit the crankshaft pulley (373 - 392 Nm) Refit the coolant pump pulley (17.6 - 28.4 Nm) Fit the ancillary drive belt tensioner Fit the ancillary drive belt Refit the air-conditioning drive belt Refit the front right wheel (88 - 108) kj_t_dba_uk_4.gif
Fit the bracket (36.2 - 53.9 Nm) Refit the engine mount carniv_j3tci_t_dba_uk_3.gif
Refit the fuel filter unit Refit the radiator hose(s) Refill the cooling system Check for leaks Reconnect the battery earth cable Torque settings Tensioner: (23.5 Nm) Timing covers (6.9 - 9.8 Nm) Coolant pump pulley: (17.6 - 28.4 Nm) Special tools Special tools are not required
Jan 06, 2013 | 2004 Kia Sedona
Mtd 42" riding mower rear drive belt keeps popping off pulley
Hi, check the idler pulley arm and return spring on that belt. Its most likely not pivoting freely allowing the belt to loosen when you operate the clutch, regards Phil.
Jun 10, 2012 | Mtd Garden
My lumina ran good all weekend with no problems. Yesterday I was driving to a friends house and the belts would squeak once in a while and the headlights and stuff would go dim for a few seconds than it...
Check coolant recevior for overfill status. Check the recevior for ckacks or damage. Check belt aligment and inspect belt for worn or adjustment. if anything is found , replace it.
sammyc47
Feb 22, 2011 | Chevrolet Lumina Cars & Trucks
How to change belt on Hoover DM6227T
Hi Diane
There are two options here; Go to the Hoover UK website and download the user manual (http://service.hoover.co.uk/manuals/Manuals.aspx?Section=6) and add in the DM6227 code and number without the T letter. The pdf downloadable (and free) user manual will upload to your computer.
Or follow this method:
There are two rear screws on the top of the hood of which you'll have to swing the handle all the way down to reveal both screws at the back of the top hood. Undo these screws and put them in a safe place. Then gently prise off the main control selector height dial and the top hood should be able to pop off easily. Then you'll main roller brush should be revealed as well as the broken belt.
Once the belt is removed, clean the brush roll of any threads or hairs that have stuck the bristles down. Then fit new belt, align the roller bar properly including the new drive belt and then refit the top hood back on, snap fitting down, two screws in and gently refit the control dial height adjuster back on making sure the front raised part of the dial knob is facing the Hoover.
Anything else don't hesitate to contact.
Nov 13, 2009 | Vacuums
My MTD Yardman HE4160 just stopped yesterday, as I look under it i notice the problem is the drive belt from front to back has popped off. I have refitted, but there is a tensioner pulley in the center...
Aug 02, 2009 | Mtd Garden
Dryer will not start. Used it yesterday, no
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Jul 13, 2009 | Kenmore 62622 Electric Dryer
Creda
remove the rear panel screws, remove side panels, pull drum backwards, slide belt down front of drum and under, refit rear panel screws refitting drum at the same time, place belt around motor spindle and reasemble, job done.
Dec 24, 2007 | Washing Machines
Mtd FASTATTACH MANUAL SLEEVE HITCH Logo
1,287 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
