Question about Jenn-Air Grilling
Can you use propane instead of natural gas - Jenn-Air Grilling
  • 60 Answers
Propane is high pressure and burns hotter than ng
Posted on Aug 12, 2009
Is it possible to convert a natural gas heater to propane
Sorry but it would not be worth doing all the work and spending lots of money buying parts, it would be better to buy a new one.
Oct 20, 2017 | Heating & Cooling
I had a natural gas furnace installed in place of a propane gas furnace. will this cause my rollout switch to trip constantly. my fuel source is propane. gas valve on furnace wasn't change to propane
If it has a position for natural gas/propane then it needs to be changed to the position that the gas source is either propane or natural gas..
Nov 22, 2015 | Heating & Cooling
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
I have a Sears gas range that doesn't burn right. Yellow flames leave the bottom of my pans black. Ther is no fuel/air mixture adjustment. I have changed the gas regulator and LP gas bottle and no change
If this is new or you just got it used and put it in and noticed the problem I am guessing that it is ported for natural gas instead of LP or Propane. The majority of gas ranges are setup to use Natural gas when delivered unless specifically ordered for Propane. If you have had it for a while and it worked fine before then this might not be the problem something else has gone bad like a pressure regulator or a line got bent affecting pressure.
If it is ported for Natural gas and you want to use propane then most companies sell a conversion kit that will make it work right.
Mar 17, 2014 | Kitchen Ranges
I need to change the stove to operate on propane instead of natural gas.
You will need to conact a gas safe engineer who will change your gas jets from natural gas to LPG, then carry out various test to makesure your flueless appliance burns the gas safely and efficiently
Jul 11, 2011 | Hotpoint Kitchen Ranges
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Oct 14, 2009 | Dryers
Where is the tank?
you will only have propane if you have a big tank out in your yard somewhere. it is possible it may be buried in the ground but there would still have to be an access for them to fill tank when it is getting low. you probably have natural gas with a company you pay monthly. call the number on your gas bill and ask if you have liquid propane(LP) or natural gas
Sep 06, 2009 | Heating & Cooling
I purchased a new natural gas range a couple years ago for our cabin. I need this range to use propane.can this oven be changed to use propane instead of natural gas?
should be able to change orifices to propane. some ranges offer these on the back of the stove or you can buy them at a local parts dealer. take your model # with u when you research a part
Jun 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Physical difference between natural & propane orfice
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Oct 16, 2007 | Reddy Heater RLP100 Portable Forced Air...
Grilling Logo
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Fred Harvey
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
