Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ed25tq side by side whirlpool fridge and freezer not cooling nor freezing. sounds like its running, you will hear a click and the light dims, then you hear another click and the light brightens. Help me to fix this at home!
deby69
  • 16 Answers
SOURCE: whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Posted on Jan 05, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 10865 Answers
SOURCE: frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on May 27, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
heatman101
  • 43501 Answers
SOURCE: Fridge not cooling, freezer not freezing even on coldest settings
From what you are describing, you have a refrigerant leak. The freon has leaked from the system, The compressor will still run and evrything looks fine. To double check you will have to have someone hookup gauges to the system and verify that the charge is lost.
It may be possible to find and repair the leak. This is not always possible as some of the system is virtually inaccessible in many refrigerators.
Make sure if you do have someone repair the system that they evacuate the system very well and do a good vacum test before recharging the system.
This should help you to solve your problem.
Thanks for using Fixya!!
Heatman101
Posted on Nov 24, 2009
Fridge not cooling whirlpool model gd5rhaxn000
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Aug 28, 2011 | Whirlpool S20DRSS33 Side by Side...
Fridge is not cooling. lights are working. freeer is working
Jul 24, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
My hoover hfa29k fridge freezer originally started to freeze the contents of the fridge and appeared to be running continuously.I unplugged it and left it for about an hour and then switched it back on...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
Try this and let me know.
Feb 22, 2011 | Hoover HFA290K Bottom Freezer Refrigerator
Whirlpool Gold GB2SHDXPS fridge/freezer has stopped working. It is not cold and food is thawing. The light in the fridge and the freezer is still on but it is not cooling.
can you hear a humming sound coming from the back of the refrigerator, if so that means your compressor is running, if you are hearing a buzz or clicking sound your compressor is trying to start, you may need a compressor. Some whirlpools have a 5 year sealed system warranty that would cover the repair.
Aug 22, 2010 | Whirlpool Gold GB2SHDXPS Stainless Steel
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Freezer and refrigerator no longer cooling
Sounds like the start relay,capacitor and overload need replaced. If you would like my assistance let me know, Thank You, Sea Breeze
Nov 27, 2009 | Refrigerators
Refrigerator and freezer not cooling
Hi, If the lights are dimming, the compressor is drawing to many amps when trying to start. If the refrigerator is under 5 years old, I would check into the warranty. If it is over 5 years, You will be better off to get a new refrigerator.
I hope this gives you an idea on what is happening.
Vic
Jun 27, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
165 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
