Question about Microsoft Office Professional 2007 Full Version for PC
Outlook 2007: 'Your Out of Office settings cannot be displayed, because the server is currently unavailable. Try again later. We are using Exchange 2007: Out of office works well for webmail. Infact two weeks ago it was working fine for Outlook until we installed a newvalid SSL certificate. Please help. I have checked EWS - Exchange Web Services and Autodiscover -- for autodiscover service all is running fine. Have check this article also : and
  • bkebbay Nov 25, 2007
    It does not make sense to do a system restore
    We install a new certificate as i said doing any system restore will just reverse everything.
    This issue affects only users using outlook 2007 and not 2003.
  • 306 Answers
Do a system retore before the last update, should solve the issue
Posted on Nov 25, 2007
  • cory casper
    cory casper Nov 26, 2007
    but you also said that it was workng before the update, a system restore wont harm or loose data, just will remove the last update so it will work correctly.
  • cory casper
    cory casper Dec 03, 2007
    remove the new certificate since it caused the problem.
Microsoft outlook menu missing
The "Out of Office Assistant" is a Microsoft Outlook feature that allows users to send automatic replies to people who send emails to them when they are out of the office or otherwise unavailable.
This feature is only available to Outlook users with Microsoft Exchange Server email accounts. Most personal email accounts through home Internet service providers do not support this feature.
If your Out of Office Assistant is missing from your "Tools Menu," it may be disabled, turned off or not installed.
Confirm that the Out of Office Assistant is installed and turned on.
To access the "Out of Office Assistant" menu command, you must be in mail view. It is not accessible from "Calendar," "Tasks," "Notes" or "Journals."
From your Inbox, click "Tools," "Options," the "Other" tab and select "Advanced Options."
Click "Add-in Manager" and select the "Exchange Extensions Commands" check box.
Try to access your "Out of Office Assistant."
If the Exchange Extensions Commands" check box is not available in the "Add-in Manager," proceed to Next Step .
Check that the "Exchange Extensions Commands" are enabled. Click "Help," then "About Microsoft Office Outlook" and select "Disabled Items."
If "Exchange Extensions Commands" is set to "Disabled," select it and click "Enable."
Attempt to use the "Out of Office Assistant" command. If it's still not available, proceed to Next Step .
Install "outex.ecf." From your "Tools" menu, click "Options" and select "Add-in Manager."
Then click "Install" and select "outex.ecf."
Click "Open."
Try to use the "Out of Office Assistant."
If you are still unable to use the "Out of Office Assistant," contact your system administrator.
Troubleshoot the Out of Office Assistant
Apr 22, 2013 | Microsoft Outlook Express
I recently upgraded an Office 2003 application to Office 2007.The Office Outlook settings,mails and other items were automatically imported when i started outlook 2007on one user account which already had...
Recheck the exchange/mail server properites and confirm they are correct. Also, check and see if it is set to Cached Exchange mode.
In Office 2007, select Tools > Accounts Settings. Then make sure the correct email account is selected and select Change while the Email tab is selected.
Nov 03, 2010 | Computers & Internet
Can i use MS Office 2007 on WinXp Home Edition Service Pack 2?
Oct 12, 2010 | Microsoft Office Professional 2007 Full...
Configure ms outlook 2007 to access my office mail it shows my inbox mail but dont shows my outbox mail or sent item & also contact list .Before outlook configure i access my outlook through web mail ....
ahhhh ok you want to access your Sent mail folder and contacts which you used when you used Outlook Web Access(OWA) "outlook through web mail" to connect to your Office Exchange mail server
in order to get this you have to configure Outlook 2007 to connect to exchange server. Do the following steps
  1. if you are running outlook close it as you can not configure exchange accounts when it is running
  2. if you are running vista, xp or 7 click on the start menu and right click on email and go to properties
  3. click on email accounts
  4. select "view or change existing accounts" click next
  5. click on any of the previously configured accounts and remove them
  6. click add
  7. select microsoft exchange server click next
  8. type name of the exchange server (you must get this from your administrator) and type in your username (name which you used to use through web mail) click on next
  9. click on finish
  10. open outlook 2007 and you should see all your previous contacts and sent items
hope this helps
Sep 24, 2010 | Microsoft Office Outlook 2007: Windows
This message pops up when I try to receive email on microsoft outlook. Task ' - Sending and Receiving' reported error (0x80042108) : 'Outlook is unable to connect to your incoming...
Probably your settings or configurations for Outlook is not properly set.
Refer to these sites for conguration settings using M/S outlook.
1. Configure outlook anywhere(MS Office 2010) @
2. Configure outlook anywhere(MS Office 2007) pdf @
Hope it helps.
Aug 23, 2010 | Microsoft Computers & Internet
Cannot start Microsoft Office Outlook. Cannot Open the Outlook window.The Server is not available. Contact your administrator if this condition persists error message when I click on the office icon.
It looks as if your outlook is set to look for a Microsoft Exchange Server. If this is the case check the settings are correct.
If you are not using Exchange then you will need to change the server type to your POP3 mail server.
If you have problems post a reply.
Nov 05, 2009 | Microsoft Office Professional 2007 Full...
Outlook 2007 will not start. Get Message: Cannot start Microsoft Office Outlook. Cannot open the Outlook window. And a big red X Hoping ican get some help on this. is there any way of reinstalling outlook...
Good news and bad news....
The good news is the problem can be fixed...
The bad news is you have to recreate your profile for Outlook, which means anything that is not still on the server is lost. If you are working with an Exchange server, this will not be an issue. You will just have to remap your PST files, if applicable.
Navigate to c:\documents and settings\%username%\application data\microsoft and look for the folder called outlook. Rename the folder to outlook.000. Now, navigate to c:\documents and settings\%username%\local settings\microsoft and find the outlook folder in there. Do the same, rename the folder to outlook.000.
NOTE: If you are on a domain, the "Application Data" and "Local Settings" folders may be located on the user's home drive (the network drive under my computer)
As soon as both the folders are renamed, restart Outlook. You will have to re-create a profile. If you are using Exchange, contact your system administrator for the specifics of the profile setup. If you are using a POP3, IMAP, HTTP, or other server, check with your email service provider for the specifics on the profile setup. Once the new profile is complete, you will be able to access outlook again.
Oct 24, 2009 | Microsoft Outlook 2007 Academic Full...
Microsoft outlook 2007 can't open
do set up some email account or just say you want to work offline. It expects some login details. May be you can just create one profile for you.
If you are not able to open try from control panel>mail .. do some R and D and you will get there.
Mar 22, 2009 | Computers & Internet
I have problems to set up my account with Microsoft Office Outlook
If you are using Microsoft office outlook 2007, open your outlook, a wizard will appear, under email accounts click yes,click next, then under auto account setup, click check box on manually configure server settings then next, choose a.) internet email, (if you have your incoming and outgoing mail server), then next, then supply all information needed, account type pop3, name, email address, account name (must be the complete email address) incoming and outgoing then password, then next then hit finish or choose b.) Microsoft exchange (if you have an exchange server and you are on a network or a company) then next, fill out the information needed, your exchange server and your email address then click finish.
If you are using Microsoft office 2003, the process is just the same..
but, if you already have an existing email on your outlook and you want to modify it, go to tools, then email accounts (2003) or tools, option, mail setup, then email accounts, (2007), on the new window, double click the existing mail then supply again all the informations needed: name, email address, account name (must be the complete email address) incoming and outgoing then password. test if successful by sending an email to your own email address
Jan 31, 2009 | Yahoo Mail
Microsoft outlook 2007 problem
also check the pop & smtp server settings or the ports used on your outlook, they must match those set by your ISP
Apr 16, 2008 | Microsoft Outlook 2003 for PC
Microsoft Office Professional 2007 Full Version for PC Logo
398 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
