Question about Samsung LN55B650 55 in. LCD HDTV
Display says 60hz always
They display in the upper left hand corner says it is playing in 60hz instead of 120hz. Is there a way to fix that?
Ignore it. That rate (60hz) is what the cable provider is refreshing at as the signal is sent to the box, but the TV will then refresh at 120hz. I know that the manual does not state this, but the TV is working correctly. Go to the "menu" and "picture" and set it accordingly.
Posted on Dec 24, 2009
Hitachi led 65" TV have maximum 120hz.but I can get only 60 hz.how to setup to 120hz..plx help me
The television panel itself is a 120hz panel, and it should be understood that regardless of the picture being fed into the television, it will always display at 120Hz. There will also be some signals being sent at different resolutions, such as 480, 720p and 1080i/p. Since the panel is a 1080p panel, the picture will also be upgraded to a 1080p picture, regardless of the source.
What you're seeing in the INFO bar are the Hz-ratings that are being sent to the television. Most sources will generally send a 60Hz signal, some will send a 24Hz signal, but all of them will be upconverted inside of the television to 120Hz. This is done by internal processing inside of the television.
Jun 13, 2016 | Hitachi Televison & Video
Touchscreen on a Garmin nuvi 1350 doesn't work. How do I fix this.
Try recalibrating it using the following method:
Nuvi 11xx, 12xx, 13xx, 14xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen. Press all of the prompted dots.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective and may need to be replaced.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Mar 29, 2013 | Garmin nuvi GPS
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
Mar 05, 2011 | Sony KV-32S42 32" TV
The "Video 1" in the upper left corner of the
Press the "display" button on the remote until all displays are gone.
Jan 24, 2011 | Sony KP-57WS500 57" Rear Projection...
Avol ALT42FD120 - frame rate change 60-120hz?
Hi. It is entirely possible that the set is already running at 120Hz after all. The display 1080p 60Hz is merely the signal it is receiving and the earlier TV's that used to claim 100Hz/120Hz merely did so using line doubling only to give a clearer picture by filling in the blanks between scanlines. If your picture is already very clear, then I wouldn't worry about it
Mar 21, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
Camera not displaying pictures I have taken
are you sure that the memory card is in the camera? if not, thats probably the problem!
Oct 10, 2009 | Canon PowerShot SD1000 Digital Camera
Game plays in 1920/1080p **60Hz**. i have a LED 120Hz TV.
the tv only gives out as much as it can, you cant improve it, srry
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
Saeco Primea Ring - no milk - just steam
Hello!!
Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
But there is a service menu on primea touch plus series.
Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
Okay, to enter the menus you have to turn you machines off.
Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
Let me know some results please!!
Apr 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Samsung LN55B650 55 in. LCD HDTV Logo
286 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
