Question about Sony MDR-XD200 Consumer Headphones
Headphone wire cut
I have cut my MDR-XD200 wires and i would liek to linke them up, iam having roblems with that, there are three wires once green one is coppper n the other red, each of em hav cotting inside and when i connect them they dont work.
    Sergeant:
  • 209 Answers
Carefully strip out the cotton strings I think this is causing bad connections with your joints and join the bare wires red to red green to green and the copper which is the earth to copper and this should work
Posted on Aug 02, 2009
Wire repair
It's not easy to repair since the wires are finer than hair and one has an insulator and one doesn't. Even if you are good at soldering and are very mechanical it may not be a very good repair. That's why they sell replacements
Nov 25, 2013 | Sony MDR-XD200 Consumer Headphones
The wire disconnected from the jack, but the rubber wire protector still connects the two. How can I fix it?
See my tip on replacing dodgy plugs/cables on heaphones. You will find it by clicking my name.
Nov 24, 2010 | Sony MDR-XD200 Consumer Headphones
My headphone jack is bent and so the headphones barely work.
THE BEST WAY TO DO THIS IS TO GET THE REPLACEMENT JACK FROM AN AUDIO OR MUSICAL SUPPLIES SHOP.. ONCE YOU HAVE THIS CUT BACK THE CABLE OUTER SLEEVE TO SHOW THE CONNECTORS AND CABLES ON THE JACK..GET A SOLDERING IRON READY WITH SOLDER.. STRIP BACK A SMALL AMOUNT OT THE CABLE SLEEVE TO SHOW THE WIRES THEN STRIP BACK EACH OF THE CABLES AND TWIST THE ENDS SLIGHTLY..GET THE SOLDERING IRON HOT AND TOUCH THE WIRE TO THE END WHILST BRINGING TEH SOLDER TO THE WIRE TIP. IF TEH IRON AND WIRE ARE HOT ENOUGH A SMALL AMOUNT OF SOLDER WILL MELT ON TO THE WIRE TIP.. DONT HOLD THE WIRE TO LONG OR THE HEAT WILL MELT THE PLASTIC COATING., DI THE SAME FOR THE OTHER WIRE.THEN UNSREW TH NEW JACK YOU SHOULD SEE EITHER TWO OR THREE CONNECTORS MATCH UP THE NEW WITH THE OLD ON THE CONNECTOR AND SILDER ON ONE BY ONE THE SAME WAY JUST HOLD THE WIRE AND IRON TO THE PLATE AND HEAT WILL CAUSE THE SOLDER TO ATTATCH TO NEW CONNECTIONS..MAKE SURE YOU HAVE PUT THE SLEEVE ON THE WIRE BEFORE YOU SOLDER OR YOU MAY HAVE TO TAKE IT OFF AGAIN TO PUT THE JACK BAK TOGETHER..TAKE YOUR TIME WIT THIS AS IF YOU TRY TO HURRY THE SOLDEDRING PART IT CAN BE MESSY AND NOT TAKE PROPERLY AND CAUSE BREAKAGE AWAY LATER IF THE JACK IS PULLED.. ONCE THE WIRES ARE SOLDERED ON TURN OVER THE GRIPS AND IT SHOULD WORK FINE.. I USUALLY GO FOR THE METAL TYPE JACKS AS THEY ARE STRONGER AND EASIER TO SOLDER.. GOOD LUCK A...
Aug 06, 2009 | Sony MDR-V700DJ Professional Headphones
Headphone wire cut ,it is not working
The cotton is a type of insulation remove as much as you need to. You also have to carefully scrape the color off each wire to expose bare wire to get a good solder joint. Remember to match the colors when resoldering.
Aug 02, 2009 | Sony MDR-XD200 Consumer Headphones
Sony mdr v150 wiring plug adaptor 4 wires green,
The green wires go to the left channel (Plug tip). The red wires go to the right channel (plug ring 2 band from tip) and the brass wires go to the ground (sleeve plug base).
May 05, 2009 | Sony MDR-V150 Professional Headphones
Jack replacement for mdr-v500 headphone
You don't need to look inside the plug... just open up the earcups and test the jack plug with a continuity tester.
But FYI, Red = ring, Green = tip.
Apr 04, 2008 | Sony MDR-V500 Professional Headphones
How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Nov 26, 2007 | Sony MDR-7506 Professional Headphones
Sony MDR-XD200 Consumer Headphones Logo
407 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
