Question about Maytag Neptune MAH5500B Front Load Washer
Leaks running a wash cycle i heard water dripping and the next thing i know the floor is soaked we emptied the load and made sure door was locked then ran another cycle and the same thing happened
  • melbjor Nov 27, 2007
    During the wash cycle I get a puddle of water under the washer. How can I stop the leak? What are the possible causes of the leak?
  • 164 Answers
Check the door boot for any signs of wear or small holes. this is the primary source of leaks in neptune washers
Posted on Nov 27, 2007
    President:
  • 1,294 Answers
Possible the leak comes from under the tub. Remove the wall plug & take off the rear panel. Check to see if the hose from the under the tub is secure, it could be the grip clip below the hose has come off. This is where it connects to the pump section. You need a grip plier or something to get it back on securely. If this is not the case take a good look to see where the leak comes from.
Next is the door gasket, maybe a tear.
Posted on Nov 26, 2007
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
Not spining properly on daily load cycle
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Mar 26, 2011 | Whirlpool Washing Machines
No spin cycle
I hope this helps.
Shane
Shane
Mar 01, 2011 | Hotpoint WMA76 Front Load Washer
My whirpool duet washing machine is locked. The cycle doesn't get completed and indicates F02. We tried to unplug it, change ccyle and numerous times the pause-cancel button. How do I just get to...
The F/02 error indicates that your washing machine is not draining properly and thus taking too long to drain the water:
  • Check the drain hose and make sure it is not plugged or kinked.
  • With Power OFF: Check the drain pump filter for foreign objects: make sure you empty the washing machine water via the hose next to the pump filter cover first without flooding your floor! Incidentally, draining all the water will unlock the door.
  • If the above does not correct the problem, you will need to get the pump replaced.
Hope the information is useful: let me know how you go!
Sep 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My wash machine wash the clothes but not doing the final spin, all the clothes all soak and wet
Handyman here -
Its possible that the door is not locking properly. If the door doesn't lock the machine will wash, but not spin the clothes dry. If you wait 15mins or so after machine is done, then set cycle to spin, it will pump any water that has dripped off your clothes out, but again it will not spin. Helps a little.
Good Luck!
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
Machine locked up. Barrel quit spinning.
first you got to empty washer by manual,get a bowl on to the floor then pull the drain pipe out of the pipe that goes outside or from under the sink,empty washer this way then the door will open,as it wont open as a result of it having water in it,when you have done this make sure you check your motor bushes,im sure that they have worn,just replace them at a cost of £10.00,they are easy to replace.rgrds paul
Jul 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ran HE3 without Water, it's now locked up
Unplug the washer and wait 30 minutes, sometimes the next morning for the machine to reset. Make sure the water is on because it while find multiple failures and lock up, Secondly you can try putting the machine into diagnostic cycle to ensure it is ok. Press drain/spin and select no spin for spin speed finally press prewash quickly two or three times and let it run, any flashing codes?, hit prewash again after writing the codes down.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Can't Open the Washer Door---Our Clothes are held Hoatage
Check and ensure that the tubes and passages to the water level pressure sensor are not blocked by caked detergent, lint , etc.
( this may have caused the water overflow in the first place)
clean up the internal parts that are wetted by the overflow.
clean the door lock mechanism. ( this normally works on a temperature delay mechanism, if cleaning does not work, replace)
all the above done with the power unplugged and water inlets unplugged , of course
Apr 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
88 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
