Question about EliteGroup P965T-A Motherboard
Additional ram hi, i am currently using a P965T-A motherboard with only 512 MB Ram and i would like to add additional ram. I already got info that i can put up to max of 8 GB of ram. I am planning to install another 1 GB ram but i would like to know if it is easy to install it by myself? Would there be problems that i would encounter or do i have to be so techy to put this myself? Please assist. Thanks,Mon
Hi, I'm also using a P965T-A Motherboard. My question is can I use a 1Gb DDR2 Kingston 533 and a 1 Gb Corsair DDR2 667 simultaneously.
Hoping for your response,
Posted on Feb 14, 2008
  • 209 Answers
Yes there might be a problem you will encounter, first, if you purchase with wrong specifications, 2nd you should be ready with the erros that will appear like the memory dumping and so on, 3rd are you familiar with the location. if you will purchase you should remove and present your existing ram so that this will be their reference with the specifications
Posted on Dec 02, 2007
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
I have a 512 mb 667mhz sdram on D102Ggc2 i decided to up grade memory. Can i upgrade system memory without lose this 512 mb.
Yes you can. but make sure that you buy the exact same type of RAM stick that you have and put it in the other RAM slot so the Dual Channel feature will be active (dual channel makes data transmission/processing faster) and making your systems memory 1GB. However, your motherboard can utilize or handle up to 2GB or RAM so you can put also a 1GB RAM stick which will make your systems memory a total of 1.5GB (that will be the case if you really dont want to lose the 512MB that you currently have,
Hope this helps.
Jul 09, 2010 | Intel D102GGC2 Motherboard
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Problems with 3 brand new PC 133 512 MB RAM in Netvista 6794
That last RAM probably is good. Many motherboards have problems using many different memory. All of the memory you have should be at least identical to ensure that they work. When RAM run at different speed or require a little more voltage, they will not let your motherboard boot. You can try mixing up the order you put the RAM in. Try putting the last RAM in the first slot by itself, the motherboard should boot. Then try the rest.
Also, whenever you add or change hardwares, you should clear the CMOS/BIOS settings.
Jan 06, 2010 | IBM (49P1599) Motherboard
He,Hi This is Abhishek from India.I wanna 2 attach an external RAM of 512MB.Will it support or not?
Hi Abhishek, not sure what you mean by "external" RAM? If you have Vista then you can use a USB drive as extra RAM using "ReadyBoost" - see link (it is Wikipedia so info could be wrong):
If you are looking to add additional RAM to your motherboard then the Aspire 3000 will take up to 2GB of DDR333 (2x1GB modules). See link to manual here:;jsessionid=32EF97E2669CCE30553D1F1544312AAA.public_a_14b?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3112&sp=page15e&ctx2.c2att1=92&miu10ekcond13.attN2B2F2EEF=3112&CountryISOCtxParam=AU&ctx1.att21k=1&CRC=3559666452
Sep 12, 2009 | Acer Aspire 3000 Notebook
How can i increase my ram in intel desktop board 815
Ram can not be increased as it is a hardware component in the computer, you can install more ram or upgrade the current ram modules that are inside the computer.
Feb 24, 2009 | Intel Motherboard
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Not able to install RAM > 512 MB
Try to run a system repair.
Jul 14, 2008 | ASUS K8S-MX Motherboard
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
EliteGroup P965T-A Motherboard Logo
64 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
