Question about SusTeen Password Wiz for PC
Apple ipod 30gb
What turn screen lock password code enter the company in apple ipod 30gb
I have an apple ipod 30gb and the lock is set and i cannot unlock it.
You can unlock iPod in one of two ways:
• Enter the combination code of 4 digit to unlock the iPod. If you enter wrong code combination, the digits onscreen flash red.
• Or Connect iPod to the main computer you use (computer with which iPod synced with), and open iTunes. Now disconnect the iPod from the computer, it will be unlocked.
Sep 08, 2009 | Apple iPod MA446LL/A MP3 Player
Tip
How to reset the password on your iPod when you forgot it
<p>Apple included an option to restrict access to your iPod through the creation of a PIN code to lock the screen and to keep unwanted users. Unfortunately forgot your password, not being able to access your music when you're on. If you draw a blank password, you can reset it, but not before you get home to your computer. Use your iPod to your iTunes software to reset the security code. <br /> <p><br /> <p>1. Connect your iPod. Enter the password appears. <br /> <p><br /> <p>2. Connect the iPod to the computer you normally sync. <br /> <p><br /> <p>3. Run iTunes and wait for the iPod name appears in the left pane of the iTunes window. <br /> <p><br /> <p>4. Click the "Eject" icon next to the iPod name in the left pane. The device is unlocked. <br /> <p><br /> <p>5. Select "Extras" iPod. <br /> <p><br /> <p>6. Open the "Lock Screen" option. <br /> <p><br /> <p>7. Select "Turn off Screen Lock" Lock Screen menu. <br />
on Jul 21, 2011 | Computers & Internet
What is a solution to unlock my Ipod 30GB?
Restore the ipod on itunes and it will remove any password locks
May 15, 2009 | Apple iPod MA446LL/A MP3 Player
Can't remember password
I had the same problem. And I coudn't remember my SCREEN LOCK Password as your son. So what I did was I just disconnecteed my IPOD while it was connected to itunes without properly ejecting. This method doesn't retrieve or resets the password, it justs opens your ipod out of the screen lock. so your son can hear his music as usual until he can get a password retreive helper.
Nov 20, 2008 | Apple iPod classic MP3 Player
Unlock my ipod
I assume the unlocking your ipod is the combination that locks the screen and not the little white tab on the top of the iPod. By plugging the iPod into itunes it should unlock it. By restoring your iPod you erase the lock but also your music. If may stay unlocked when you remove it from the computer. Good luck.
Aug 26, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 30gb 5thg error 1418 help please
my screen is locked but it don't hav a pass word
May 16, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod Model A1136, 30 GB.
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Feb 14, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod
just restore your ipod to factory default. Then just change your password or your security code, what ever you call it!
Jan 03, 2008 | Apple iPod nano
Apple iPod MP3 Player 30GB
Wow sorry to hear about that :: Here is the info you need :: According to Apple, if you have forgotten the code, you can unlock the iPod nano or iPod by doing the following: Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data." I hope this helps
May 07, 2007 | Apple iPod MP3 Player
SusTeen Password Wiz for PC  Logo
19 people viewed this question
Top SusTeen Computers & Internet Experts
David Payne
David Payne
Are you a SusTeen Computer and Internet Expert? Answer questions, earn points and help others
