Question about Hunter 20537 / 20538 The Vista Iron Ceiling Fan
I have a hunter ceiling fan (model #20537) which makes noise at low speed. Sounds like ball bearings need oil. Any suggestions?
I climbed up and took a look at mine and found 3 small holes by the down rod & gave each a couple of shots of WD40, so far it seems to have worked at least the noise has stopped
Posted on Nov 11, 2011
  • 5,546 Answers
Check with stores that sold it and see if they will warranty replacement. I think there is a lifetime warranty, thats why you pay the big bucks for the Hunter name.
Posted on Aug 02, 2009
How do I oil my Hunter fan?
You don't. There's no place to oil ANY ceiling fan, not just the Hunter line. All ceiling fans use sealed ball bearings in the motors. They are lubricated for life. If you're experiencing a squealing noise, it would be best to take it down, pack if up and take it back where you bought it. No ceiling fan should squeal, let alone one as expensive as a Hunter.
Apr 22, 2011 | Hunter Dryers
My fan makes noise it old n how do I check the oil level?
Hi, It is not using the oil but greaser. You have to resemble the fan to get your bearing to be oiled / greased. But I suggest you to replace the bearing.
Feb 08, 2011 | Hunter (25417) Ceiling Fan
The fan makes noise and vibrates when it runs
Howdy,
First off, is this a newly installed fan, or an older unit? These fans use oil for lubrication of the bearings, is the reservoir full of oil? Are the blade brackets which hold the blades to the motor loose? Check those screws and the oil level. Here is the owners manual to your fan
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41121.pdf
Sep 16, 2010 | Hunter 23827 Classic Original White 42"...
Hunter Ceiling fan lost medium speed, kept hi and low. Speed control capacitor melted. Replaced both capacitors (speed and start) AND switch. Still no medium speed. Is it possible part of the motor...
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Aug 12, 2010 | Hunter Ceiling Fan Control Switch
HUNTER CEILING FAN SOUND LIKE THERE ARE BALL BEARINGS ROLLING
The type noise is crucial in knowing the problem. Is it an electrical humming sound. To find out, place it at high speed, then turn off the power. did it go away or is it still there. If it isn't the electrical, it may be the bearings. The older types have an oil reservoir that needs lubricating. the newer ones are sealed bearings. try a little WD40. make sure you keep this lubricant away from the electrical components, because it has a reaction to certain plastics
Apr 05, 2010 | Hunter (25417) Ceiling Fan
Fan makes grinding noise when on speeds two and three. . . sounds fine on slow
The bearings are wearing out, speeds two and three are exerting enough force that the bearings are grinding, slow speed does not have enough force to do this. Soon enough, slow speed will make that noise and the fan will ultimately stop working. Have an electrician come in to look at it, if it is still under warranty, call Hunter.
Sep 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Ceiling fan makes a clicking noise
just apply some lubrication and if necessary change the ball bearings. u r all set
Oct 07, 2008 | Hunter Dryers
Hunter 20537 / 20538 The Vista Iron Ceiling Fan Logo
601 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
