Question about Dryers
Motor works fine, hot air fine, belts fine, pulley has come loos on the shaft as it is worn out, can we replace the pulleys
  • 67 Answers
Yes the pullys are easy to replace you just need a snap ring remover about 2 dollars at an auto parts store.
Posted on Aug 15, 2009
I do have a 1999 grand marquis my belt is kind of loos i change a new one and also change a new tensioner and a new pulley but still have my belt loos
From the sounds of your description there has to be a wrong part or belt route. When you put the belt on after installing the new tensioner, did you have to hold the tensioner back while putting the last section of the new belt on? If so then the tensioner cannot be the correct one for the vehicle. Or the belt was not routed correctly.
What motor, Does it have air conditioning
Your feed back would be appreciated.
Jan 14, 2014 | 1992 - 1999 Mercury Grand Marquis Belt...
RPM OK here we go: motor 1725 3/4 shaft..arbor 4" pulley dedicated prefer to leave on,,old line shaft type..has 2 -3 1/2 pulleys and flat belt works too, up to 3" wide..1/2 " V-belt..all on a...
Have you ever thought of a Motor Speed Controller, sort of a "Dimmer" for a motor? That way you could simply adjust your motor speed to what you want and compensate the error out?
Feb 14, 2010 | Air Tools & Compressors
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Washing Machine Shaft Wont Move
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 08, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Making scraping sound when spinning
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Nov 06, 2008 | Zanussi Washing Machines
Older kenmore washer doesn't agtat the frist load but works fine the rest of the day (has new belt) moter works fine
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
From Repairclinic
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Samsung fully automatic washing machine
HI The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Oct 14, 2008 | Washing Machines
My LG washing machine
Oct 13, 2008 | LG WM-2077C Front Load Washer
Hoover 200 m unbalanced and noisy on spin cycle can't balance it
Sep 13, 2008 | Washing Machines
Hi,Ihave a hoover hnf 7167 washing machine that my 2 year old turned off then on again while on a 1600 spin(the washing machine,not the 2 year old!!).This caused a loud'pop'and everything went blank.The 13...
thank u................
Sep 12, 2008 | Hoover Washing Machines
Dryers Logo
27 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
