Question about Panasonic Televison & Video
No TV lineup
When I press the guide button on my RCA remote I get ''No Data for this Screen''. It worked fine up until several weeks ago but now I have no TV Guide on my screen. I have not changed VCR for three years.
    President:
  • 1,734 Answers
Ask here, they can get remote codes and manuals for every RCA remote and TV. Send them both model numbers.
Posted on Aug 02, 2009
Need remote code for an RCA television
I have had several remotes; 1 was RCA. Resetting the remote was the same on all - 1. turn TV on, 2. press and hold code search button until light goes on (some flash, others stay on), then release 3. press TV button, release once light goes on 4. press on button every 10 seconds or until TV turns off - up to 100 times pressing button!! 4. press enter . Now the test... turn TV on - good luck
Jan 02, 2013 | Televison & Video
One for all urc 7110 guide button
For lg hdtv the method to hold the magic button for a while until led for tv is on and pressing code 991.then power off button and ch+ button for 35 times untill your tv switches off and back on several times and back ch- button.This works well for hdmi cable connection as well as to set the magic remote to work with guide and AV button properly.Then input for hdmi works well.many thanks.
Apr 12, 2012 | Televison & Video
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
The guide menu keeps popping up and it loses the remote programing. I cleared it out once by pressing several buttons, including the power and mute button simultaneously until I gained remote control...
You have bad switches inside the tv. When a switch gets stuck nothing else will work including the remote. In other words, the microprocessor can take only one command at a time. Replace all the switches at one time to avoid trouble later.
Oct 13, 2009 | RCA Televison & Video
My RCA HDTV remote won't work with the regular tv. It was working fine last night until i pressed the tv botton and the volume button.
One thing you can try is to take the batteries out of the remote and then press every button on the remote, then replace the batteries. I have used this technique several times and it works. If that doesn't help try leaving the batteries out over night, this may reset the remote.
I hope this helps.
asnowman
Aug 01, 2009 | RCA HD52W59 HDTV Projection Television
How to put cod in rca remote. for rca sdtv
press tv button, then press and hold setup button, then press power button several times until tv shuts off. As SOON as it shuts off, press enter.
Jul 05, 2009 | Televison & Video
RCA Guideplus Gemstar TV
one of the button switch is still working or stock up, you need to replace all the switch to besure.
Oct 31, 2008 | RCA F32649 32" TV
HOW TO PROGRAM RCA RCU310 Remote Control
1. turn device on.
2. hold code search untill light stays on
3. press tv, vcr or whatever you want to program once. (light should still be on)
4. press on and off button untill your device turns off.
5. click enter on the remote. should be good,
6, dont forget to go outside now and then,
Mar 02, 2008 | RCA RCU310 Remote Control
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Televison & Video Logo
121 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
