Question about Whirlpool Washing Machines
The door will not open. the machine has not been working correctly and now the door will not open no matter what we do. We have unplugged a lot of times.
    Top Expert:
  • Whirlpool Master
  • 78,919 Answers
Make and model of the machine please
Posted on Dec 09, 2009
My GE front loading washing machine has a locked door but is not operating correctly due to frozen pipes. Can I get the door open to retrieve my clothes? Thanks!
unplug it,remove the top lid or if it has a bottom panel that comes off either way stick your hand down to where the door lock is,on the bottom of the door lock there's a round release,pull it down and the door will unlock,next time send the model number,also you can try unplugging it for like 5 minutes,plug it back in and the door might open but if it doesn't unplug it again and feel around at the bottom of the door lock assy. pull down on the bottom ring and it will manually open the door.
Jan 08, 2018 | GE Washing Machines
My BOSCH Axxis 24201UC washing machine displays "E:16" (which means "Door not closed properly") all the time, no matter what, and is inoperable
Check that the door switch is closing when you close the door with the latch mechanism. Unit will be dead unless the switch is closed.
Sep 20, 2017 | Bosch Washing Machines
The door wont lock and the buttons wont work
Morgan,
1. unplug machine and let it reset. I spoke with a parts supplier who set it could take up to 3 hrs.
2. this was our fix - check door latch. it needs to send a closed signal to operate. un plug machine - remove top - i would try to lightly spray switch with WD-40 - plug in and try it. if it does't work -unplug it again -replace switch . If WD-40 works I would pick up a switch it is only a matter of time for that switch.
I hope that does it.
Emmy
Mar 21, 2014 | LG WM2487H Front Load Washer
Lamona HJA8553 Washing Machine door release has suddenly stopped working!! Is there an emergency door release to get my wet washing out??? tried turning off at the wall in hope of resetting the machine...
My Lamona integrated washing machine HJA 8553 has a nasty smell coming from it like an old damp mop its making the whole of the house smell any ideas why
Jun 30, 2011 | Washing Machines
E40 error door light flashing and clicking noise
E40: Door open, Interlock, wiring or main PCB most likley going to be faulty door interlock.
Turn the power off, unplug the machine and take the top off your machine and on the front right of the machine there is a plastic case with lots of wires.
Put the wires out one block at a time, keep putting them in and out, this will help the connection to seat.
Try the machine again and the problem should be solved.
If not you may need a new board.
Mar 10, 2010 | Zanussi IZ161S Front Load Washer
Can't open door of lg wd-1018c washing machine
Hi, I don't know if this is much help to you now as it has been a while since you posted your problem. I had the exact same problem and after a lot of swearing and 2 days and no help what so ever from LG I took matters into my own hands.
I took the top off the the machine and removed the small steel plate, you will know what I am talking about after you have done the same.
I had my hubby hold the tub back as far as possible and used a screw driver to release the latch which is at the front of the machine about half way down. You will see a small silver steel knobby looking thing. After the machine was finally opened I unscrewed the screws on the inside of the door and used a flat screw driver to prise the housing apart. Be careful not to drop the glass window as when the housings start coming apart the window is no longer secure.
I found that a small piece of plastic on the handle had perished and broken not allowing the correct function. A phone call to Sunstate spare parts got the new handle to me within a few days at a cost of $20.95.
My only problem now is putting the bloody thing back together. I have been at it for 3 days with no sucess. If you manage to work out how to put yours together please let me know. I hope this has helped and hasnt come too late.
Cherie.
Sep 29, 2008 | LG WM-1832C Front Load Washer
Maytag MAH-24 door won't open
sounds like something in pump go there first
Aug 16, 2008 | Maytag MAH2400A Front Load Washer
Error message wont go away
unplug machine from mains for 5 mins then try it. close IRE
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool AWM5125 - door won't open
i unplugged mine from the wall and that worked
Nov 29, 2006 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
