Question about Water Heaters
Pressure shows 0 psi greenstar 30si
How do i increase pressure on boiler?
  • 154 Answers
Open the water feed by raing the brass flat lever to 12 psi
Posted on Aug 03, 2009
When running the bath the water is hot for the first minute then becomes lukewarm for the remainder.
possible weak flow check screens in faucets or turn down pressure switch
Jan 04, 2018 | Water Water Heaters
Why does the pressure guage indicate zero a few days after adjusting to 1.5 Greenstar 37CD Boiler
This will show that you have a water leak on your boiler or pipe work .
Aug 17, 2016 | Water Heaters
Why does the pressure rise to over 3bar when the central heating is in operation ?
3 Bar = 43.5 PSI When you heat water it always expands increasing pressure.
In a closed vessel volume can increase by 2-3%. Either expansion tanks allow for this and PSI is maintain or without an expansion outlet the PSI will increase in proportion to heat supplied.
Is this a low temp hydronic boiler operating at or <140F, a hi temp hydronic boiler @ >180F or steam boiler?
Oct 18, 2014 | Water Heaters
Greenstar 30si
this is your safety valve letting by first try and check ur pressure bladder shud b 28lbs squr inch if it isnt pump up to 28 what happens if the bladder has no pressure then the water has no were to go but out through to pipe water expands when hot and thats why un have to top up the other problm is safty valve worn out needind replacment hope this helps u Susan
Sep 21, 2013 | Water Heaters
The water pressure on my Greenstar 25Si Worcester Bosch combi boiler is so low that the shower won`t heat up. Can someone please tell me how to increaese the water pressure as there doesn`t seem to be an...
The boiler has a filling connection which uses a filling loop to connect the boiler to the mains supply for the initial fill and subsequent fills.
See the link below from the manual you can buy the filling loop connection online or ebay its a simple task to replenish the pressure. Worcester GREENSTAR 25Si Instruction Manual Filling The System
Feb 06, 2018 | Water Heaters
I have an Amtrol 109 tank on my boiler mounted horizontally (all the literature shows the tank mounted vertically). Lately, the pressure on the boiler slowly bleeds off. I've been told the Amtrol tank may...
If you are losing boiler pressure, it is probably not the expansion tank. Most of the time when these go bad they fill with water and cause a increase in boiler pressure, especially when the boiler is running. If you put a tire gauge on the end of the tank it should read between 10 and 15 psi. If this is the case then the expansion tank is fine. If the tank is fine then you may have a leak somewhere in the system. The perculating that you refer to could also be from the boiler being under filled. Make sure all zones are purged of air and the boiler pressure reads around 12 psi on the gauge. Hope this helps
Oct 24, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Worcester bosch greenstar 25Si?30Si pressure gauge showing high
a couple of things , is your filling loop disconected ? , and are all your radiators blead from air, have you got a high point where the air can get stuck in system say pipes going into roof etc you may need to fit a air release valve in line at highest point to remove the air from system , your boiler should be around 1.5 bar running preasure average setting . if you are constanly filling with water you could be exceeding the pressure valve limet which releases pressure from system this could be faulty ?
Feb 02, 2009 | Water Heaters
Water Heaters Logo
914 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
