Question about Toshiba 55H70 55" Rear Projection Television
Cannot recieve digital channels worked fine before & works when plugging in a seperate digital box
  • 822 Answers
Pls check all cables if installed properly
Posted on Aug 02, 2009
  • 98 Answers
Do you have a cable box? Do you have HD with your cable box? They charge us $10 more a month for it, and I have an HD TV, but you still have to have THEIR cable box attatched to the TV to get HD Channels. Sucks, don't it??
Gooman ld2667d tv is not recieving any digital channels, using the same ariel port as before. unplugged the tv to put onto a new stand and getting no digital tv channels. Signal is 0 % too. Before i...
The range and the airial antena have trouble recieving the new location air signal.Try buy a new digital antena and install it.Auto tuning it again.Should work fine.
Aug 12, 2011 | Goodmans 289NS 14" TV
My sub will not work when input is tv/cbl. it works for DVD and CD. My cable box says the signal is Dolby 5.1 but receiver does not show that mode. using RCA jacks for connections. Used to get 5.1 and sub...
hello,if your using rca plugs from the cable box than dolby digital 5.1 will not be present. You need to use either an optical or coax or hdmi cable from source to the reciever to recieve digital audio.
Dec 07, 2010 | Denon AVR-2308CI
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
I have a philips TV that is digital 27PT8302/37 32PT8302/37 and I cannot get any digital channels I also have a winegard amplified Antenna, and I am connected to dish, All was working well and now after...
you should have a seperate tuner [marked digital] to hook up the antenna then tell menue where to look and reprogram
you could use a box and use channel 3 or 4
i assume you have the dish hooked to auxilary in
Sep 01, 2009 | Philips 27PT8302 27" TV
Channels lost on starview box
Yeah i had the same problem with starview 4. i upgraded the firmware and still no good. i then by accident set the default key. it worked. i'm not sure if it will work for u.
Aug 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
I have had an outdoor antenna for several years to recieve HD local. Before the conversion I purchased a Samsun HD Tuner. It was working fine will all channels working and guide providing all program...
8 11 & 14 are std definition. All digital channels are 1.1, 1.2, 1.3, etc. You may need to re-align your antenna. Digital is Very Very direct, analog was very scattered. Hope this helps
Jul 08, 2009 | Samsung DTB-H260F
I've lost all digital sound to my reciever.
Get into the cable box menu and look for audio settings, chances are your digital output from the cable box is off. If you still can't get audio, reply with your Cable Box Make & Model and I can help you further. Hope this helps
May 25, 2009 | Yamaha RX-V757 Receiver
Sansui HDLCD1908 not recieveing Digital channels
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
Jan 06, 2009 | Sansui 19 in. LCD TV
Starview3 digital receiver codes for cardiff south wales ntl
Subject: Star View 3 The Box Suoper when channels discappear ;o)
Hiya this is what I did & hopefully it'll work for U too - 1) Deleted all th channels & reset 'factory settings' by entering the code 0000, turned th box off waited a couple of minutes & turned it back on !!! 2) You may have to redownload channels so reconnect yr box to the computer & follow the link below (But try without doing this & goto stage 3) first & please let me kno if that works :- http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess ) & press download !!! 3) ReConnect & Turn box back on; goto menu & press 1570 to get into the CASS SYSTEM & turn EMU on Reinstall channels & voila
Dec 02, 2008 | StarTech.com StarView SV211K 2-port KVM...
Toshiba 55H70 55" Rear Projection Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
