Try keeping the button pushed and see if that is happening anymore, it worked for me :)Try keeping the button pushed and see if that is happening anymore, it worked for me :)
You can't post conmments that contain an email address.
Try turning down the brightness on the monitor, sometimes this will fix the issue, if not the problem is in the inverter board and needs a professional to assess it further.
my BenQ FP71G 17 in goes on after hundreds of times pushing on off switch and when it's on it does not go off, I have checked the on/off switch which is working oke and when the moniter is on the auto adjust message (brightness and contrast)pops up frequently and the screen adjusts itself.
radioactivet, A qualified technician will need to investigate the units "switch-mode-power-supply" for typical "faults" and locate the faulty (bad) component(s) that ma be causing monitor to act this way. "Noise" on the +5 volt DC rail going to the vga/lcd interface (processor) may be why display is acting "strange" with uncalled for pop-up's appearing!! That's the very first place I would investigate when dealing with ANY COLD-CATHODE-FLUORESCENT-LAMP, BACK-LIT LCD DISPLAY. 12fixlouie
I have a Benq that was continually auto adjusting, I used electronic cleaner spray on all the controls (a good spray) and now there is no problem, suspect the controls were sticking, especially the on/off and the auto adjust button
I would recommend you to bring it back and get a new one, if its till
under warranty. You cannot fix the problem on the panel buttons it
looks something to do with the components in the circuit bord.
which button?
