Question about LG 42PX4DR 42 in. Plasma TV
Line on my LG (model 42lcd2d) LCD tv
I have a line on my LCD Tv in the middle running from top to bottom. it is not there all the time ,the color of this line varies with the background , going from red to black.
  • 31 Answers
SOURCE: 50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Posted on Mar 10, 2008
SOURCE: LG flat panel plasma with red line
I had the same problem and fixed it by replacing the control board. It's a little nerve wracking, but required only simple hand tools. If you'd like to see detailed pictures of the repair check out my blog.
Posted on Feb 04, 2009
  • 92 Answers
SOURCE: purple line down middle of screen
I could do with a digital photo to be sure, however it sounds like the LCD panel itself has failed.
Posted on Mar 28, 2009
  • 458 Answers
SOURCE: my Lcd tv has a thin green line running from top
Unfortunately this is a problem with the screen & the only solution is to have it replaced. If it is still under warranty then there should not be any problem if however it is not, then it would be uneconomical to get the screen replaced as this can be very expensive.
Posted on Dec 09, 2009
  • 161 Answers
SOURCE: Red Pixelation on LG 42PC1D Plasma
This may help. No guarantees tho.
Posted on Jan 15, 2010
SOURCE: I have a Samsung plasma with red lines on the top,middle, bottom
I just got this same problem. suddenly appeared in same manner you describe.
Posted on Mar 23, 2010
0 characters
1 Points
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET -
Jun 10, 2015
More results from
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
Sep 2, 2014 - Uploaded by
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Lg 42LD450 center line in the middle
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | LG 42LD450 42 in TV
I have a green line running vertical on my 42 inches lg tv., How do I fix it?
Check its main power regulator board for any damaged electrolytic capacitors. Replace the suspected.
Feb 25, 2013 | LG Electronics 42 in. LCD Tv
40 inch Philips tv has a brown line in the middle of the screen, can it be fixed???
is this an lcd or plasma tv?. then does the line stay in one area or it was moving while the tv is working?. can you give this some detailed which can help out solve the problem.
Oct 16, 2012 | Flat Panel Televisions
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
LG - 32LD350 - 32" LCD TV - 720p is the type of tv
It has been permanantly damaged, and is not repairable. To get it work perfectly, you have to replace the screen. OK.
Aug 03, 2011 | LG 32LD350 32 in. LCD TV
There is a blue line down the middle of my sharp lcd 32sb24u tv.
Hello; If this line is razor thin and goes fully from top to bottom, the LCD Panel is bad and costs more than a new TV. Time to shop for a new set if this is the case or just put up with the line. John
Mar 25, 2011 | Sharp LC-32SB24U 32 in. LCD TV
LG 42PX4DR 42 in. Plasma TV Logo
147 people viewed this question
Top LG Flat Panel Televisions Experts
Are you a LG Flat Panel Television Expert? Answer questions, earn points and help others
