Question about Sharp AR 201 Copier
Ar-160 display says "check panel" no more codes or functionality
The device is actually a lanier multifunction copier 5216AH which i believe is a sharp ar-160. I got it at a garage sale and it supposedly works but from first power up all it does is do a system check then displays "check panel" no codes and no further functionality. No other buttons work only power off. Any help would be appreciated.
    President:
  • Sharp Master
  • 1,447 Answers
Tis problem is some of panel button is short i mean it is lock please open your machine panel board and service it . then solve your problem
Posted on Aug 02, 2009
Our Lanier copier is showing a wrench. What could be the problem?
Could be an error code, is there a number preceded by an sc displayed on the panel?
Aug 01, 2011 | Lanier 1205 Copier
Hello there i have a lanier color copier everthing work and functional fine acceipt when i want making color copy, i press full color button the display panel show TO USE THE FOLLOWING FUNCTION [ S ] SET...
Hi, whoever administrates that copier has set it up for key counter management, which means that unless you supply the correct key (which is typically a card that you swipe or a code you enter) you can't make color copies. If this is your copier, you can disable key counter management:
- Press the User Tools/Counter button. - Go to System Settings. - Go to Admin Tools. - Find the option for Key Counter Management and turn it off. - Exit out of User Tools.
Now you should be able to make copies normally.
Dec 02, 2010 | Lanier UNKNOWN
Hello there i have a lanier copier model ld 160c color copier everthing work fine and functional acceipt i can not make full color copy, when i press the full color button then the display panel show up TO...
Hi, somehow the external key counter option for your copier got turned on. This option is typically used for coin-operated copiers such as those found in libraries. You can turn this option off by doing the following:
- Press the User Tools button - Select System Settings - Select Admin Tools - Select Key Counter Management - Choose Off, or de-select the full-color option if it is selected. - Exit out of User Tools
Now you should be able to copy normally!
Printer displays 510 error code. I need the local service center address
HI
Got this from usa canon.com website click here and type error code in the search box
a list of the error codes will be displayed and you can then click on the relevant one.
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request."
Jun 20, 2010 | Office Equipment & Supplies
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Feb 02, 2010 | Lanier Office Equipment & Supplies
Have a lanier 6735 with an ''A1''Code
Hello sir; A-1 code means discharge corona cleaner problem, check it up may be the cleaner not function right.
Oct 16, 2009 | Lanier Office Equipment & Supplies
Canon mp830 error code 5010
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
Nov 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Remove error in AR-5316
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
AR-201 shows "check panel"
plese write the error codes coming on the display
Sep 23, 2007 | Sharp AR 201 Copier
Sharp AR 201 Copier Logo
95 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
