Question about JVC Cybercam GR-D200US Mini DV Digital Camcorder
JVC GR DVL9800 - Vista won't recognize
I cannot get Movie Maker on Windows Vista to reconize this camcorder. Are there drivers out there for JVC GR DVL9800? I have no CD's. JVC is from 2001. Thx - JW
  • sandi4t Dec 25, 2007
    I am unable to transfer video from my JVC GR D 70 cam to PC having vista OS. earlier i had no problem with Window XP. Roxeo starts capturing the video but it is not saved in file. i use USB cable. I have tried Pinnacle and windows movie maker but no success.
  • MrWYZard May 11, 2010
    I also have the same camcorder with the same problem, once I have the FireWire cables, can I upload the video I recorded to the computer as a video file?
I have the same camera and use vista without a problem. However I use the firewire interface and not the USB which might be the explanation.
By the way, I can't find my manual. The date and time don't stay saved for any length of time between use. Is there a baterry that need to be changed and if so where is it?
Posted on Mar 21, 2008
My computer doesn't recognize my JVC Everio camcorder
i use the video to Windows Movie maker below successfully import the footage
Check JVC to Windows Movie maker Converter
Apr 11, 2009 | Cameras
How to upload recorded movie to PC using USB
Do I need a driver so that Windows XP recognize my JVC GR-D850 when I connect it thru USB port? If I need, where can I get it?
Mar 24, 2009 | JVC GR-D850 Mini DV Camcorder
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
I have jvc GR d720 dv camcorder but unable to connect .. driver required ... i have firewire send me in
No driver required for Windows XP. I simply plugged in the camera via FireWire. Windows automatically recognizes it as a digital video device. Then I started up Windows Movie Maker and followed the wizard to capture the movie from my digital video device. It was really easy.
Oct 24, 2008 | JVC GR-D720 Mini DV Digital Camcorder
My computer no longer recognizes my JVC GR-D70U mini DV cam when I plug it into a usb port.
Hi, I am not sure. But I believe the camcorder has to be on when you connect to the computer. and I assume you use firewire for this particular camcorder.
I too once had this problem when I used Windows Vista. If you too use Vista, try it with Windows XP.
Sep 19, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
I found a Fix for vista with my GR-D850 jvc the (3 port IEEE-1394 firewire PCI Card) works on vista when installed the pci card I was able to down lowed to windows movie maker with no problems.
I hope this helps
Aug 27, 2008 | JVC GR-D850 Mini DV Camcorder
Windows vista will not rcognize my camcorder
Make sure Vista is updated, plug in the firewire on the computer side first then to the camera. Movie maker should start right up!
Good luck
Mar 01, 2008 | JVC GR D370US camcorder Mini DV
Your JVC is a MiniDV camcorder, which uses a Firewire connection for capture. Firewire drivers are standard for all DV camcorders, and built-in on every version of Windows since about Windows 98SE (well, they didn't work very well until Windows 2000).
You still need a capture application to complete the transfer. Most (maybe all) versions of Windows comes with Windows Movie Maker, which is a very basic program, but it can do this.
Normally, a DV camcoder can't be detected by Windows until you have it connected via Firewire, and have it the appropriate mode. On some cameras, this can be play or record (the latter would tranfer live video, or allow recording TO the camera), on others, you need to set the camera to a "link to PC" mode. I currently own Sony and Canon camcorders that both work in the former way, but my first DV camcorder was a JVC, and it did have to put in a "link to PC" mode to be detected by the computer. If you can't find the setting, you might want to check your user manual.
For still photos, it looks like you use a USB connection. I haven't found all the details on this camcorder, but this is likely to be a normal USB "storage class" connection. If so, your camcorder would show up like a disc drive, and you can drag photos over. Vista will support this by default, too.
The other way some older camcorders send photos is to appear to the system as a USB scanner type device. You would need a device driver for this, from JVC.
The user manual would be helpful here. You can get one via download if you don't have it:
Jan 20, 2008 | JVC GR-DVL310 Mini DV Digital Camcorder
Transffering video
I hope you have received software CD and Drivers when you buy your camcorder. you will be able to use Windows Movie maker come with windows XP if you have installed drivers.
Dec 11, 2007 | JVC GR-DVL820U Mini DV Digital Camcorder
JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
488 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
