Question about Refrigerators
Not cool enough
My hotpoint fridge have some cool air blow out but not as cool as before even though already turn to Coolest level 9,. milk already smell little bit bad... and i got breast milk there as well.
  • wilson0825 Aug 03, 2009
    amazingly can't find any model number label at all.
  • 75 Answers
Can you cofirm what your model number is,this will be on a tag inside the fridge behind the salad box or behind the bottom draw in your freezer.
Posted on Aug 02, 2009
  • neilmoto Aug 03, 2009
    ok approx how old is it?has it got a digital display if it has is it in the middle at the top or to the left?.
    is there an adjustable buttons if so how many?are they on each side of the display?,or are there buttons to change the display from compartment to compartment(fridge,freezer)
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
How to change the temp in a frigidaire galaxy refrigerator
Units will vary give or take a few degrees from the control panel display. Keep in mind once you change the temperature it will take up to 10-12 hours to stabilize and reach that temperature. If the unit is not cool, even at the bottom of the refrigeration portion (where the coolest air will be found) then contact a professional to diagnose the control pane and board.
Dec 29, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
My hotpoint top freezer is not cold enough. The ice creams are all melted. I don't see any knob at the top for adjustment. There is a adjustment a the fridge level. I already turned it up to the hightest...
Let the level be set at midpoint and for a start put the fridge off for thsystem to come to normal , the compressor to reset. Now draina nd clean all the cooling coils inside the freezer unit. Look for visible wearing off wires or connection in the temperature sensors. Check lines to the timer, heater and the thermostat. remove panels to check . now clean the compressor contactor and aster all the panels are put back, restart the fridge. If the cooling returns then you willhave to wait and watch if the timer works to auto deffrost. if not replace. If the cooling is still bad then you must check for hte weeakness of the compressor, low pressure of gas. service and refill gas but I would recommend with a good help. Get extimate before you start he work and ask for time warranty for the work. Hope you work this out. Good day
Jul 31, 2010 | Hotpoint HTS16BBSL Top Freezer...
Got a hotpoint ffa97, freezer was still cold and no alarm had gone off to say that that there had been a power cut yet the fridge temp had risen enough to curdle milk??\r\ntemp gauge was still showing...
Milk can sometimes curdle in a working fridge. But it does sound like your defrost system may be malfunctioning. Can you empty your freezer and inspect the defrost system behind the air circulator fan?
I know that defrost elements sometimes go bad and the controllers can pop too. You should check your operators manual and see how to put the fridge into manual defrost. *(it usually involves turning the fridge light on and off by hand. See if the freezer drains during manual defrost. If you have lots of food that dries out in a frost free unit the moisture contains a lot of contaminants that can plug the defrost drain. Which leads to a blocked air passage between the freezer and fridge sides.
You might want to get a small backup fridge for a while to run this down.
Or just use up the food in your fridge before running the tests.
Good luck and be careful.
Jun 28, 2010 | Hotpoint Refrigerators
Freezer cold, refrigerator warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 10, 2009 | Refrigerators
Side by side fan in back doesn't
A temporary solution for this, is to use a fan to blow some air to the back of the unit. Looks like -as you already figured- the condenser fan is broken. If your fridge starts cooling with the external fan, you may have keep it working on this way until it is fixed.
If you had previous service in your appliance, perhaps the tech guy forgot to plug the fan connecto to the power.
Aug 30, 2009 | Hotpoint Refrigerators
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Fridge not cooling
evidently the fan that runs in the freezer and blows air into the main fridge has a circuit issue or the fan is frozen, but if the bulb does not work then its a circuit issue. likely on the same circuit as fan.
Mar 20, 2008 | Refrigerators
Bad Milk
I think your defrost drain is clogged so the water is draining into floor of freezer. The extra moisture is freezing the damper to the fridge so it isn't getting enough air. Hope this is some help so long after you posted the question.
Sep 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
