Question about OKI Electric Industry C3520 Laser Printer
PRINTER NOT WORKING
I GOT ERROR MESSAGE IN OKI PRINTER C3520 MFP
ERROR IS 155:FATAL ERROR
  • 95 Answers
That is a fuser code. Turn off and take out fuser(the part that gets hot) and inspect it. Put it back in and turn back on. If code is still there replace fuser.
Posted on Aug 02, 2009
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Error message: Service Call 980 - Fatal Error
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
Fatal error 708
Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
Dec 14, 2010 | OKI C3530N Color MFP Printer
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
OKI C3530 Fatal Error 031
Hi.. i only remove the memory ROM in the board and refixed it, then i turn on the printer and now its working :)
thanks Admin
Feb 19, 2009 | OKI C3530N Color MFP Printer
Toner sensor error
The toner cartridge has a small window from outside where the dark blue handle. You should turn a photodrum gear wheel while the window will not open. After that insert a drum unit and work.
If you have "start cartridge" that doesnt work....
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Error Code 155: Fatal Error
Looks like a fuser error-
re-seat fuser
check for paper scraps, etc in fuser and printer.
Service call
155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Reinstall the fuser after its
connection connector is cleaned
if error still exists-
Turn on the power supply again
Replace M32 board after check
the cable connection.
Jul 29, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI C3530 MFP
Looks like a fuser problem.
Re-saet the fuser.
Check for pieces of paper, etc. in the path.
Service call 155: Error
Defective fuse
cutting of fuser
Yes
If error still exists_
OKI Electric Industry C3520 Laser Printer Logo
633 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
