Question about Dell (E210882) Motherboard
No power after 5 second
I am working on DELL 1525 that it doesnt turn on, when I press the power fan works for 5 second then It turn off without any signal, what do you suggest?
  • notre_dame75 Aug 02, 2009
    Thanks alot but can you tell me what is psu?
    Sergeant:
  • 263 Answers
Check the cpu fan and fins are clean if you have to take processor out make sure you reapply thermal compound, Also check the ram is seated correctly.Also check the psu is functioning correctly as it could be a faulty psu . Good luck John
Posted on Aug 02, 2009
Dell laptop not booting up
there may be problem with motherboard,the battery or cor processor or can be any hardware problem.
Feb 08, 2013 | Dell Inspiron 1525 Notebook
Inspiron 1525 mother board problem can i fix?
It does seam like a mother board issue ..but I suggest to check the CPU ..if you can get one with a similar socket ..even if it is smaller on properties...just to see if it works ..cause usually when you do have power indicators..and the fan works ..it shows that the motherboard have power ..so it may be ok ..and only the cpu may have issues or something ..So my advice is to see the socket time (see the specs for the laptop ) ...get another one ...second hand but be sure even if it is a cheap one ..that it is functional ..and try it on ..It might surprise you ..In my oppinion ..this is a clear cpu failure..(remember that the fan is powered up from the motherboard..and if this one is faulty there isn't power present .on the fan nor in the indicator led ..
Nov 22, 2011 | Dell Inspiron 1525 Notebook
Inspiron 1525 motherboard problem can i fix??
Try to run the diagnostings
Try this http://adf.ly/3pDUa
My daughters 1525 dell laptop will not work properly.You can turn it on the dell name appears and that is it all lights are working fan is working I hope you can help with out me she has all her photo;s...
If the power LED is ON and you can sense the fan as well problem might be on the LCD or Motherboard.
Could you please try this one and give me feedback what had happened.
Remove ac adapter and battery from laptop.
Press and hold down power button on the laptop for 10 seconds.
Plug in the ac adapter.
Hold down the Fn key then press power button once, then just keep holding down the Fn key.
You might not see anything on the screen but please do take note of the error code or beep codes.
Thanks!
Apr 29, 2011 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
Hi, my laptop powers up but no screen appears. just the left two blue lights go on and then power light stays?
Turn it off, unplug it, remove battery, then press and hold power button for 5 full long seconds. Wait a couple minutes, put battery back in, plug in and turn it on.
This should fix the problem. If it still persists, check memory chips or try removing just one and see if that helps. Bad memory chips can cause this. But try first solution first.
Apr 17, 2010 | Dell Inspiron 1525 Notebook
Laptop keeps turning off laptop only stays on for 5 minutes, max, before powering off. no warning, just turns off. battery and power cable/converter is good. Tested with another 1525 battery and cable....
Two factors usually cause this
Factor 1: Overheating due to Dust and Dirt contamination inside the Notebook.
Open the Notebook and blow it with an Air blower mainly near the processor area.
Check the CPU cooling fan is working properly or not.
if the fan is not working properly even after the cleaning then you need to replace it.
Factor 2 : Virus, Worm or Malware infected system cause the system to repeatedly restart ot shutdown.
get your system clean with a good Antivirus like "Kaspersky Internet security 2010" or A-squared Anti-Malware. Both can detect malware,adware, spyware,trojans etc.
Check out which one work out for you.
Jan 07, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 touchpad not working properly
You can try the following steps.
1. Turn laptop off.
2. Remove all external devices and disconnect AC adapter power cable from the system.
3. Remove the battery from the system.
4.Hold down the power button continuously for at least 5 seconds. Do not release the power button during this process.
5.Insert the battery back to the system.
6.Power the laptop back on.
Try using touchpad again.
Dec 29, 2008 | Dell Inspiron 1525 Laptop Jet Black
Dell (E210882) Motherboard Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
