Question about Olympus Cameras
My Olympus TG-3 Tough digital camera will turn on but it won't do anything and turns itself off a few seconds later.
The menu, info, and all functions do not work. It is not the battery as I have tried several new batteries that work in the same camera owned by others.
SOURCE:
t00nz
  • 4738 Answers
SOURCE: A95 PowerShot turns on and off until batteries die.
Sounds like you have a stuck power button or shorted power switch. To repair you'll need to remove the top cover. Please see the following disassembly guide. It's in Estonian, but you can follow the pictures.
Continue to page 2, paying particular attention to the second and third picture. It looks like the power switch is connected to the camera through a simple ribbon cable. I'd suggest removing the ribbon cable end from its connector, cleaning any obvious crud, and then reseating the ribbon cable end into its connector. Ribbon cables are notorius for suddenly shorting or getting a bad connection at the connector. Usually just jiggling the cable can fix it too :-) Good luck!
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
By the way, were you the person that left a similar comment on my blog? http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
Posted on Feb 01, 2008
SOURCE: Olympus Stylus 730 Digital - Won't work 60 days old
I'm having the exact same problem. I was in the middle of zooming on a shot and it froze, so I turned the camera off and on, and now I get the 5-chimes+Zoom Error screen. This is nuts, I've only had the thing for six months, and it was $250 (got the Stylus 730). I *think* I got a replacement plan so that's good. But still... I hope circuit city lets me get a different brand b/c I'm not happy with this now. The only problem I had before was the HORRID shutter delay. I want a model that doesn't have that problem .
Posted on Mar 29, 2008
SOURCE: Camera won't turn on
im havin the same problem
Posted on Oct 23, 2008
JaxPlanet
  • 922 Answers
SOURCE: Kid Tough Digital Camera Error 50
It sounds like your rechargable batteries might be bad.
Try a new set of batteries. It might be a cheap fix.
If this helps please vote for my solution.
Posted on Aug 27, 2009
Testimonial: "I would never have thought to take out the SD memory card to solve this problem. This was an easy, no-cost solution. Many, many thanks!"
  • 6771 Answers
SOURCE: my olympus tough tg-310 got wet inside with salt water form the beach now it won't turn on please help.
There is very little that can be done, salt water will corrode metal on contact, all eletronic parts have been compromised, if the memory card is still intact save your pictures and remove it from the camera to transfer to new hardware. Replacing the camera unfortuneately is the only option.
Posted on Apr 02, 2012
Remove moisture inside Olympus digital camera
Place it in a sealed container covered in rice for a few days. The rice will absorb the moisture. Works on cell phone dropped on water too.
Sep 02, 2014 | Olympus TOUGH TG-310 Digital Camera
Copy between internal memory and SD card on olympus TG-1
Use the "Backup" command in the settings-1 menu. See page 45 of this manual.
Jan 14, 2013 | Olympus Tough TG-1 iHS Digital Camera...
Replacement lcd screen
You maybe able to get one from this WEB site.
www.lcdparts.net
Sep 27, 2012 | Olympus TOUGH TG-310 Digital Camera
Can't upload video from camera to pc Olympus TOUGH TG-310 Digital Camera
Do you have Windows Live Photo Gallery? It comes with Windows 7, but if not you can download it here: http://windows.microsoft.com/en-US/windows-live/photo-gallery-get-started
  1. Open Windows Live Photo Gallery
  2. Connect your camera
  3. Click the Import icon in the top left corner.
  4. Select your Olympus and click import. It should import both photos and videos.
You can also try and select the videos you want using the file download module Windows displays when a new device is plugged in. If that doesn't work, try
  1. Start > Computer > Olympus Tough TG-310
  2. Then open the folders until you find the videos you want. Select them and copy them to your desktop (or any other preferred location).
I have had video issues with my Olympus TOUGH (could not delete them from the camera) which turned out to be a formatting problem with the memory card.
Aug 16, 2012 | Olympus TOUGH TG-310 Digital Camera
Olympus tough tg-310 wont let me take pictures
Camera CCD unit fault. Repair cost approx 100$.
Aug 07, 2012 | Olympus TOUGH TG-310 Digital Camera
My olympus tg 310 is stuck with the lens open and won't come on at all even when a fresh battery is installed
If the camera is within warranty, return it to where you bought it. Common fault with a few different brands, to do with a lens open sensor within the lens assembly itself. Maybe allow the camera to dischage without the battery for a few hours and see does it power on with a new battery. Also chack the battery, if it has bubbled it a dud, and check the battery contacts within the battery compartment.
Jun 05, 2012 | Olympus TOUGH TG-310 Digital Camera
My olympus tough tg 310 will not turn on, charge or be recognized by computer
The Olympus Tough TG-310 digital camera is a waterproof device that has great power to withstand any type of harsh weather conditions. This device has been engineered in such as way that you can simply put it in water, but remember that it can only sink up to 10-feet of water.
Apr 09, 2012 | Olympus TOUGH TG-310 Digital Camera
My olympus tough tg-310 got wet inside with salt water form the beach now it won't turn on please help.
Apr 02, 2012 | Olympus TOUGH TG-310 Digital Camera
My Olympus Tough turns on but immediately starts beeping for 10 seconds then shuts off. It does this over and over.
Your rechargeable battery is no longer serviceable. You need to replace it with a new battery. This camera uses one Olympus lithium ion battery*. No
other type of batteries can be used.
* TG-310: LI-42B
TG-610: LI-50B
Caution:
There is a risk of explosion if the battery is replaced with the incorrect battery type.
If you would like the manual, please send me an email to LBrown18062@hotmail.com and I will send it to you right away. Please put "Olymp TG-310" as the subject. Lawrence Brown
Jan 20, 2012 | Olympus TOUGH TG-310 Digital Camera
Cameras Logo
111 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
