Question about Tascam DP01FX All-In-One Recording Package Microphone
Tascam DP01-FX/CD I have been using this for months without a problem until now. The play button does not respond so now I cant play my songs of record new ones.
    Uploaded 5 video answers.
  • 150 Answers
I tell you connect to the computer your device
and right click on your device and format it i have the same prob now it fixed
Posted on Nov 25, 2007
I cant open my cd tray on my tascam dp01
Look on the front of the CD tray for a little hole... push the end of a paper clip in the hole and the tray should open.
Dec 12, 2009 | Tascam DP01 All-In-One Recording Package...
I cant seem to record more then one song
When you create a new song you switch to the new song automatically. To get back to the old one you just have to 'load' it from the list of available songs. As long as you shut down properly the song you are working on is automatically saved. It will automatically load again until you either create a new song or load another stored song.
Feb 25, 2009 | Tascam DP01 All-In-One Recording Package...
Unfortunately it's pretty much impossible to get a recording to sound like anything produced commercially these days without using lots of compression. Your burned CD problems might be the result of a faulty burner on your DP01-FX/CD. I have a 2488 and I still export all my mastered songs as wav files and burn them onto disc using my PC just because of the flexibility on the PC and you can control settings better which can cause disc burning problems (not to mention that the burner is newer and faster on my PC).
If you don't want to work on a PC you could look into replacing the burner in your Tascam. It is similar to replacing a PC's burner and the either the Tascam site and/or the Tascam Forum should be able to provide you with the specs and a list of compatible CD burners.
To get the final product to sound louder you could invest in an external compressor (a good used one should run you less than $100). You'll have to use the DP01's send loops to route a bounce of the stereo mix out to the compressor and then route the result back into the DP01 inputs and record on a couple of free tracks.
Hope this helps.
Oct 14, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam dp01 fx cd.. OOPS!!! Please help.
Depending on the voltage that your laptop uses, if that voltage exceeds the Tascam required voltage you might have burned out the Tascam power board. Not good. I know you don't want to replace the entire unit. Try contacting Tascam directly they might give your an alternative in just replacing the power assembly.
Sep 20, 2008 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD sound quality of CDs
Nothing really specific other than to make sure you are recording as close to 0 db as possible without going over. Your master fader also needs to be set at 0db or above as this effects the volume when mastering.
Commercial CDs use a lot of compression to attain volume levels which aren't attainable without it. You should however be able to reproduce onto CD the volume levels you are hearing on your Tascam without resorting to compression.
To troubleshoot, you might want to try exporting your master tracks as wav files onto your computer via usb and then listening to them there. If the volume is low there you aren't creating master tracks with good volume (see above: master fader level), if the tracks sound good as wavs on your PC, then burn them onto a cd from there. If that CD has proper volume then you may have some problem with your Tascam CD burner although I've never seen a situation where a burner actually caused low volume like this.
Best of luck.
Apr 21, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01 FX/CD
Check to find out the size of the active FAT partition. You may have a 'less than optimum' amount of memory left in that partition. Switch to another partition and see if you can record in that one.
Dec 04, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
Hooking my tascam dp01 to the pc
hey i had the same problem u need u.s.b 2 or something like that because some computers have u.s.b. 1.5 or something wierd along those lines i fixed mine by plugging mine into the back of the computer in the usb port there.
Sep 25, 2007 | Tascam DP01 All-In-One Recording Package...
137 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
