Question about Briggs & Stratton Garden
The gas tank on the B&S is leaking at the
The gas tank on the B&S 124k020155-b1 is leaking at the seam. Is there a glue or epoxy thet can be used
    Genius:
  • 1,114 Answers
Yes, there are products on the market for gas tank repair. Your local auto parts store should carry these products. Just review them to determine which one will best meet your situation.
Hope this helps, If so Please rate, Thanks.. Good Luck..
Posted on Aug 02, 2009
Coolant leak,
Strange but do you think a hose has a pin hole that is spraying coolant up?
check the inner hood for over spray.
Clean the engine then drive it & look for more obscure places that might be wet.
Feb 19, 2014 | 2007 Dodge Nitro SXT
Liquea gasolina por la parte superior del tanque de gasolina dodge durango 2005 motor 3.7
follow the steps for fix it. God bless you
Instructions
    • 1 Drive until your gas tank is nearly empty, ideally until the fuel level is below the gas tank leak, if possible. You can determine this by routinely stopping and checking for oil leaks. If oil is still leaking, the gas tank is still filled above the leak. Use brake cleaner to clear 6 to 8 inches around the leak. Wear gloves and protective glasses while you work. Do not let your gas tank completely empty before you perform repairs.
    • 2 Use a scraper and sandpaper to remove road tar, rust or grime around the leak. Use brake cleaner on the area again and allow it to dry
    • 3 Remove the epoxy from its packaging, taking the same amount from both sticks. Mix the epoxy together, massaging it between your fingers until it is the same color.
    • 4 Form epoxy into a cone shape and push it into the hole or leaky area. Use a plastic spreader to smooth the remaining epoxy into place. Allow the epoxy to completely cure. If the leaking problem persists, take the car in for professional repairs.
Oct 18, 2012 | Cars & Trucks
WHAT TYPE OF ADHESIVE CAN i USE TO REPAIR A LEAKING COOLANT RESIVOUR
you can try a plastic weld type epoxy they make some for plastic gas tanks as well try that remember to clean and scuff the surface
Aug 12, 2012 | 2002 Lincoln LS
What do I do when fuel tank is leaking.
what is it on?where is the leak? the seam the fitting on the bottom try some 2 part epoxy from a auto parts store for plastic fuel tanks
Apr 28, 2012 | Garden
Is there a picture of part placement? gas is leaking
Check the fuel lines for decay or other damage. Make sure that none of the lines have been replaced with plastic--use only the original rubber type. Check the carburetor fasteners for tightness. If the fuel seems to leaking from the case, you may have a cracked tank. If so, replace the tank as no glue or epoxy will provide a permanent repair. Check the fuel filter, air cleaner and muffler for plugging. Good luck!
Jul 06, 2010 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
My two part gas tank leaks what do i use to seal it with
If the tanks are plastic, the best fix is to replace them. Most epoxies, silicon, and other glue bases don't bond well with plastic and the vibration of the running saw doesn't help the repair either. Hope this helps!
May 12, 2010 | Garden
I have a leak in my windshield washer resevoir.
if you can see the hole they have epoxies that can repair the leak. some come with a fiberglass tape that you put into the epoxy to give it strength. check with your local auto parts store.
Nov 09, 2009 | 1999 Pontiac Sunfire
Coolant tank leaking can it be seal with exposy glue.
yes, this can be sealed.. use some Epoxy waterproof clay used to seal roof rain gutters. Put a decent amount of clay to solve your leak problem.
May 26, 2009 | 2002 Daewoo Lanos
Leaking maax shower drain, can I remove the grate and seal it from the inside?
try this:
you might but it will depend if it is pvc then yes any other material you might be able to use a waterproof epoxy but it will harder to repair because of the epoxy but the pvc you can prime and glue the seam from the inside..
Nov 09, 2008 | Maax Shower Drain 10000041-105
Leaking gas tank
Assume you damaged the gas tank. If you broke a line or filler neck this won't work.
Raise vehicle (safely) and clean tank - careful not to spark - NO GRINDING. I use regular sand paper. Find the hole - sometimes takes a bit of looking. If small, here is an old trick: rub the corner of a bar of soap over the leak and if done correctly, it will stop the leak (no, you're not done). Clean the area around the leak a little better - still careful of sparks. Get some epoxy that will stick to metal wet with gas (from AutoZone). Seal the hole with this epoxy and you should be good. Work quickly - the working time of the epoxy is less than they say it is.
good luck.
Aug 06, 2008 | 1996 Ford Taurus
Garden Logo
258 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
