Question about Casio Cameras
Casio pcr275 reading error 10. Have unplugged but did not fix
I have cash register casio TE-100 error
Error and not format?
Here are some resources:
1) Error messages: http://www.manualslib.com/manual/25907/Casio-Te-100.html?page=80
2) Setup: http://www.ycr.co.uk/faq/download/A%20YCR%20DOCUMENTS/Warehouse%20Setup%20Sheets/Casio/Casio%20TE-100%20Setup.pdf
3) User's manual: http://totalpos.co.nz/wp-content/uploads/2012/10/Casio-TE100.pdf (post finalization of receipt format p. 43)
4) Casio helpline for registers: 800-706-2534.
5) Casio support page: http://www.casio.com/support/content/D799D5A7-9C01-40E0-8D11-071A11F4A9A9
6) a commercial service with some experience programming such machines: http://www.ccr-retail.com/cash_register_program-support.htm
Jan 06, 2015 | Computers & Internet
Range error on casio graphing calculator
Open the window configuration ans set Ymin to -10. You can also access the ZOOM function and select Zoom Standard.
May 07, 2012 | Casio FX-9860G Graphic Calculator
Keepr reading lens error
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 15, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
How do i clear an error code on a casio cash register?
Not positive, but I think you have to unplug the unit for 5-10 seconds then plug it back in. Some require a certain key position and operation of certain buttons to clear the codes.
Jul 23, 2009 | Casio Parts Cash Register PC Desktop
Casio WK 3300 Display Problem
Flash error problem on casio wk 3300
Mar 31, 2009 | Casio WK110 Portable Keyboard
Casio CE-3700 giving E008 errors!
Hi.
Yes, it definitely is the CLERK function. When you enter 0 CLK#, you are just logging off (which has already been done), so that is normal for it to accept that. If you can't get in with 1 CLK# then I'd say someone has setup special codes for this machine (PIN numbers). You will need to do a prog. read. Also, if you have four raised CLERK buttons just below the keylock, one of them should be pressed down. (they are an option on some versions). Try 1 CLK# or 2 CLK# or 3 CLK# ... up to 7. If none will log you on, let me know, and I'll tell you how to do a read on it.
Mark
Apr 30, 2008 | Casio Parts Cash Register PC Desktop
Casio CE-3700 cash register MAC instructions
Hi. I would advise both of you to try a flag clear first to see if you have any program left.
Turn key to program. Power off at wall.
Hold RECEIPT FEED, and turn power on at wall.
Wait 10 seconds, then let go of RECEIPT FEED.
When you see 'FFFFFFFFF' press SUBTOTAL.
Turn key back to REG and try it.
If you still need help, let me know.
Mark
Apr 15, 2008 | Casio Parts Cash Register PC Desktop
System Error (OeO1)
With a system error there is actually no way to fix this problem at home, it will need to be sent in for service. A system error is internal in the camera and usually is a software issue. The service center's number for Casio is 1-800-706-2534, then option 1.
Jul 14, 2007 | Casio Exilim EX-Z57 Digital Camera
HELP SYSTEM ERROR
Hi Ann, have you tried turning it on with the memory card out? Is there any other code appart from the "SYSTEM ERROR"? for ex - 0e01 ?
Jun 24, 2006 | Casio Exilim EX-S3 Digital Camera
Cameras Logo
57 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
