Question about Canon PIXMA iP1800 InkJet Photo Printer
SHOWING LINK RUN OUT
For newly installed link catridge canon 1800 showing message box
"following lin is run out " color 831.Replace the link catridge and close the cover
    Sergeant:
  • 263 Answers
Check thecartridge is installed correctly and you have taken the sticky tape off it.
Posted on Aug 02, 2009
(canon pixma mp145) I have been using black and color original catridge for few years, but suddenly unable to use my printer. It shows E5 and on the dialogue box is stated that it cannot recognize the...
Uninstall and reinstall the printer.
Make sure you have the install disc before you do this though.
If you do not have it you can get one on the Canon web site.
Apr 03, 2013 | Canon PIXMA Office Equipment & Supplies
I had refilled my canon 831 color cartrige but it is not working and it is also blocked non of the color is printed in pattern check. how can i resolve cartrige blocking problem????????//
Open the printer and remove the catridge
Use a tissue paper and clean the nozzle where the ink comes out from
After you have cleaned the nozzle, press the catridge on the tissue and see if the color stains the tissue
If it does, you put the catridge back into the printer and then try to print.
Jul 06, 2011 | Computers & Internet
The printer is showing a message catridge error - Refer to device documentation to troubleshoot.
This is an internal electrical malfunction within the cartridge - I suggest you run the following two service tests:
1) You can 'temporarily' bypass an 'Incompatible Cartridge' error (or any other cartridge electrical malfunction error for that matter) by accessing the OJ's service menu...see the Inkjet411.com support youtube video found here:
HP Officejet J4500 J4600 4500 Cartridge Error Bypass -- HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
2) You can also run the 'tap 41' diagnostics check on the HP 901 cartridge(s) electrical health, via the access code/procedure shown in the following video:
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics -HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
Jan 17, 2011 | HP Officejet 4355 All-In-One InkJet...
How to fix service error on canon ip1800
You will need a resetter. Download this software and follow these steps.
Step 1: Reset hardware
  1. Press Resume button hold for 1 – 2 minutes
  2. Open the cover
  3. Release the catridge and then put catridge again
  4. Close The Cover
  5. Turn Off
  6. then Turn On again
Step 2: Reset Software using general tools
  • Download software resetter or general tools for canon pixma iP1800 http://www.mediafire.com/?nmfns4hixel :Driver should have been install correcly.
  • Connect USB cable.
  • Before connect power, press and hold power button then connect the power.
  • At the same time Hold power button, and press reject button for 2 times then release power button.
  • Run software resetter for canon iP1880.
  • Don’t forget to open lock release in the software. ( note : to view locK release menu, min resolution 1024 x 728)
  • Then select Set Destination to iP1880
  • Check CLEANING and EEPROM CLEAR
  • Click MAIN and PLATEN
  • Finally test print by click TEST PATTERN1.
Mar 18, 2010 | Office Equipment & Supplies
I cant print it is showing e5 on printer screen
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-3
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Ink run out - with newly installed cartridge
Try another cartridge and see if the error message goes away. You may have gotten a bad cartridge.
Jul 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I installed new ink catridges and the little box still shows that the ink is low. it showed now that there is now black ink left, cant print. What do I do?????
i installed rerefilled collor catridges 831 and the little box show that ink is low and 831 ink has run out
what do i do please help me
Apr 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
110 people viewed this question
old marine
old marine
