Question about Acer Aspire One PC Notebook
Hello, i have acer aspire one notebooki and have all the time white screen, so i cant work
  • 37 Answers
I have seen this sort of problem in Dell Inspiron 6000 it was missing the bottom 1/3 of the screen (kinda white etc). If you push around on it, close to the frame, on the bottom left corner, it may come back. It’s worth trying before pulling it apart.
Posted on Aug 02, 2009
    Novelist:
  • 129 Answers
Hi..
Your problem are related with my laptop problem, but i totally fix it with my own. From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
hello, i have acer aspire one notebooki and have - 1-laptop-white-screen.jpg Here’s an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor hello, i have acer aspire one notebooki and have - 3-video-cable.jpge laptop.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because thhello, i have acer aspire one notebooki and have - 4-reconnect-video-cable.jpghe back side of the LCD screen.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting thhello, i have acer aspire one notebooki and have - 5-disconnect-lcd-screen.jpg help, most likely you have a problem either with the LCD screen or with the motherboard.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnhello, i have acer aspire one notebooki and have - 6-test-with-another-lcd-screen.jpgcreen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose you using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but ihello, i have acer aspire one notebooki and have - 7-white-lcd.jpgine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen.
7-white-lcd.jpg After I'm assembled everything back together and connected the original LCD, it’s still white.
In my case this problem is related to the LCD screen and it has to be replaced.
That's my laptop brand and model, and i am searching an image regarding about my problem. This problem are common to another brand.
Hope it may helpful for you!
Good luck
ICmanServer
White Screen Problem while starting Acer Aspire 2710z laptop
Unfortunately it sounds like bad memory. Depending on your memory configuration you can try swithing out memory sticks. Check with your manufacture about memory configuation requirment before trying this. If you're unsure how to do this it's best to take it to someone who does know how.
Mar 25, 2010 | Computers & Internet
Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Dec 01, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer Aspire 9300 turns on with black screen
Hello!!
Try entering thro the safe mode ... and restore the system. let me know the updates.
Cheers!
Jun 23, 2009 | Acer Aspire 9300 Notebook
Acer aspire 4530 - crystal eye problem
  • Hi has the webcam ever worked? If so what happened to stop it working? The webcam on Acer notebooks is part of their Vista software so if you uninstalled by accident you would need to reinstall the application that runs it aswell. Acer notebooks have a useful utility called Acer Erecovery Management which you can use to reinstall. Goto Start, All Programs, Acer Empowering Technology Acer Erecovery Management.
I hope this helps
Apr 04, 2009 | Acer Aspire 4530-5889 Notebook PC
White blank on acer 4315
It sounds like a Bios issue.
Go to http://support.acer-euro.com/drivers/notebook/as_4315.html
Download the latest Bios for the windows you are currently running and follow the Readme.txt and update the bios.
Hopefully this will fix the issue that is connect with the monitor and power setting in the bios.
Please Rate, Thanks.
Jan 06, 2009 | Acer Aspire 4315 Notebook
Acer Aspire 5585 Laptop LCD Problem
You need to replace the inverter of your lcd screen.
Oct 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Aspire 3004Lci Graphics problem...!!!
Open the Control Panel, then Display, click on Settings tab and examine the specifications for your software to see if the current settings are correct for it.
Sep 04, 2008 | Acer Aspire 3004LCi Notebook
Help with my acer peace of s___
Looks like a faulty screen as other guy said in other post :(
Dec 13, 2007 | Acer Aspire 3100-1405 Notebook
Acer Aspire One  PC Notebook Logo
658 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
