Question about Vacuums
2000 blend door not operating air going every where, engine drops to 400 rpm at decell then resumes 700 as normal steering wheel lock motor replaced 7-3-09 25 miles ago ideas?
  • Vacuums Master
  • 19,396 Answers
The blend door is vacuum operated.
Check the vacuum for leaks using a tool like this : Fuel Pump and Vacuum hand Gauge...
Check with particular attention the vacuum hose that goes to recirculation vacuum motorunder the hood. Start from there, as that is a common vacuum leak that can cause trouble to the blend door.
The blend door actuator is fine, or the blend door won't open at all.
Look for vacuum leaks.
Regards.
Posted on Aug 02, 2009
The roller shutter does not stop while rolling up, noting it has a motor, what would be the problem?
The "up" limit switch is not working. there will be one to stop the door going up and another to stop it at the bottom.
They could be magnetic or a contact micro switch, check the door track and look for something at the top of the track with wires coming out and see if it lines up with something on the door when it is in the normal open position.Similar to a burglar alarm contact on a door or window. You could try putting a magnet next to it as the door is opening to see if it stops or if it is a mechanical switch try operating it manually (preferably with an insulated screwdriver)
Nov 08, 2016 | Vacuums
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Wertheim x3000 motor running but little suction?
Check all of the filters. When there's extra heat, it's usually blocked filters.
If not, dismantle the wand and use long pipe cleaners or a bottle brush to clear any possible jams in the wand or head. Remove the hose from the main unit and if possible, drop ball bearings or marbles down the hose to try and clear any blockage. Remember to recover all of the ball bearings or marbles before you reassemble the hose and wand.
Aug 13, 2014 | Vacuums
Why are the brushes turning until they are placed on the carpet?
The brushes are not powered by a motor but by the exhaust of the vac motor. They must have lots of air to even turn at a slow RPM. You may have a lint blockage on the air which cuts the volume of air to the turbine that spins the brushes. Look for lint on the filter. I recall it was on the operators left side on the base of the machine towards the front.
Jul 06, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How to clean/lubricate bearings on Dirt Devil motor?
If you know some one with compressed air blow out all dirt particles best as possible then get a 3 in 1 oil or sewing machine oil drip along the motor shaft and turn by hand you will be able to free the difference once lubricated it should only take a few drops per side . let set for awhile and repeat . then put her together and see if motor speed returns to normal . also check turbine wheel for slipping on shaft.
May 01, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
Here is the webpage: http://uksupport.irobot.com/app/answers/detail/a_id/1047/kw/iRobot%20Roomba%20Discovery%20SE%20Bagless%20Robotic%204200%20series%20Vacuum%20beeps%203%20times/related/1
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | iRobot Roomba Discovery SE Bagless Robotic...
My roomba 550 goes round and round going know where.all the rest work ok
I have the complete service manual for the 550 series. It is in PDF format and if you would like the complete manual, give me your email address and I will send it to you. Below is the basic cause and repair for your irobot's condition.
Circling at slow, normal or rapid speed:
Most common causes: Dirt has infiltrated the wheel encoder or a drive belt has failed.
In MOST cases, the robot's software will recognize and correct the behavior within minutes. If the battery was recently reset, the robot may act erratic again at startup until the software has a chance to correct the condition. • If the Robot does not resume normal driving behavior within the first couple minutes of runtime, go to DRIVE WHEEL Module inspection and cleaning (Appendix C). If cleaning wheel modules does not correct the problem, both wheel modules may need to be replaced. • Replace drive wheel modules if fixes fail.
Happy Holidays
Dec 16, 2010 | iRobot Roomba 550 Vacuum
I have an older Electrolux canister vacuum - model #2100 and the temperature sensor shuts down the motor. How to I take apart and clean?
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
Dec 14, 2009 | Electrolux UltraLux 2000 Bagged Canister...
It's an old cannister electrolux vacuum cleaner and it's not worth to have it serviced. The motor is noisy it appears to be obstructed but I can't open it since I don't see any screws. Would you please...
You will need to peel the soft rubber bumpers away from the side, like pealing a banana. Grip the bumper tabs with needle nose pliers from the bag area with door open. Underneath will be a set of locking keys which slide forward ONLY out the front of the machine. Once they are removed the front of the vac will scissor open allowing the rear housing to drop off. This is normally done in a cradle in a shop. Tag your wiring harness before removing the motor. The motor slides up out of keyed slots. replacement is the opposite.Rubber O ring is a motor seal and must be clean and properly aligned. Motor MUST reinstall with housing in slots. Check your fans for dirt and bearings for replacement. 8mm shaft size 108 bearing???
Jul 03, 2009 | Electrolux Guardian Bagged Canister Vacuum
Can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
