Question about Brother LS-2125 Mechanical Sewing Machine
Lower bobbin thread tangling and breaking - Brother LS-2125 Mechanical Sewing Machine
  • Brother Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
lower bobbin thread tangling - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 02, 2009
Kenmore 158 12271
the bobbin case is not located properly. take it out check the bobbin fits fully inside it.
Feb 18, 2014 | Sewing Machines
Why is my brother sewing machince lower thread tangle
try changing the needle
try a different bobbin
make sure the bobbin is wound correctly and not over wound
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
make sure the top thread has not come off the thread take up lever
Nov 29, 2012 | Brother Sewing Machines
Lower bobbin thread gets tangled
try changing the needle --make sure the needle is the right one
for the fabric being sewed
try a different thread
make sure the bobbin is not over filled
make sure the thread has not come off the thread take up lever
Oct 04, 2012 | Brother XL-3500
My thread keeps breaking when I sew
Tension is maladjusted. There is a tensioner on the front of your machine. If it is too tight (turned clockwise) the thread will break. Also could be the bobbin has tangled. Remove it and check for tangles.
Aug 18, 2012 | White Sewing Fashionaire Sewing 2380...
I place the fabric on the machine, lower the foot and apply pressure to the foot peddle, when the machine begins to sew fabric is pulled down and the lower thread tangles, the machine make a crunching...
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Dec 21, 2010 | Brother XL-3500
The lower thread is getting tangled. I have changed the bobbin, re-wound the bobbin thread again, taken the bobbin out and cleaned the bobbin case.
Incorrect threading of the top thread can also cause lower loop tension problems. As can the wrong size or blunt needle. Try re-threading top thread first.
Dec 21, 2010 | Brother Sewing Machines
Thread is tangling on the lower bobbin
check the needle first.Bent or spurred needles will result in this action.
May 30, 2010 | Brother XL-3510 Mechanical Sewing Machine
I can't keep the lower thread from getting tangled. I have rewound bobbins, cleaned the bobbin case, made sure the bobbin case is in the correct position, and played with the upper thread tension. When...
Ensure that you have routed the bobbin thread properly. Also, if the bobbin case is not installed properly it will give you this problem. Ensure that the protrusion is touching the spring on the body of the machine.
Jan 27, 2010 | Brother CS-6000
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    Thread breaking.
    Rethread the machine following these directions:
    all machines thread the same. TTN tension, take up, needle.
    Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
    (To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
    Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them.
    Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works.
    Make sure the thread is through the take up lever.
    sewman7
    Sewman7
    Jul 09, 2008 | Euro-Pro Fast and Easy 420 Mechanical...
    Brother LS-2125 Mechanical Sewing Machine Logo
    733 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
