Stopped mid cycle
I have a hotpoint ultima wma76 and last night it just stopped mid cycle. It is full of water and won't empty or rinse. I managed to turn it off at the mains then restart it with just a spin cycle and it made lots of clunking noises, filled up with a bit more water and aggitated but then stopped again.
Have turned it off and on many times trying different cycles but nothing at all is happening now
  • glenswatm588 Aug 02, 2009
    Have managed to get it going twice more but each time it just fills up with even more water, chugs along for a short time then stops completely. Deseperate for answer, need clothes to wear to work tomorrow!
  • 98 Answers
I think I answered one like this the other day...verify this before doing it....does your washer have a dial or a computer panel?
If it's a dial, then remove it and checker the disc underneath it, if it has some "teeth" missing, then it would be the timer that needs to be replaced, very simple to fix.
If it is a computer panel, you will need a repairman to help you with that, he may prefer to do it alone?? LOL
Good luck
Posted on Aug 02, 2009
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 water level switch loaction?
Should be located under the lid near the top edge, round shape with a tube going to the bottom of it and wires in the front. To remove from the frame turn the whole thing 90 degrees as fitted with with rectangular fitting on rear.
Jan 21, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 stopped spinning is the motor /brushes in top or bottom of casing had other hotpoints and the brushes seem to go evry 5 yrs or so? are they as easy to change as the older models?
it is as easy as the older modles but the motor is at the bottom and you have to take out the motor to replace the carbon brushes hope this helped.
Aug 29, 2009 | Hotpoint WMA76 Front Load Washer
FDW40
This is a blocked pump,Strip down pump and remove blockage.
Jul 24, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint WMA76 Ultima 6kg
either you got a clog behind the drum or a clog in the draining tube behind the washer i would call sears or where you got it to get someone out there to check it out or if you got the manual of the washer and specs to see maintenance tasks that it requires if you know the make and modal i could get that for you ..
djkb
Jun 26, 2008 | Hotpoint WMA76 Front Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
