Question about NetGear Computers & Internet
I need a workaround for the Kasa smart plug to connect with my Netgear Orbi WiFi - 5.0 multiband
SOURCE:
sharksupport
  • 14 Answers
SOURCE: hELP IS SOMEONE USING MY WIFI CONNECTION
You are safe as long as you have all the security measures enabled on your router. What you are seeing is people that are in close anough range that has their own wireless network also. Mine will pick up as far as 5 houses away from where I live at. There are several here. Hope this answers your question?
Posted on Nov 25, 2007
  • 192 Answers
SOURCE: connection wifi problems with ds and netgear
it might be a WEP password which is located on the botom of the router.
Posted on Jan 04, 2009
  • 23 Answers
SOURCE: Trying to connect to home wifi with netgear router and EEpc G2g
Chekc your security settings, it can be that Eeepc not correctly determine security settings. Try to set all security for your SSID manually.
Posted on Apr 19, 2010
kakee
  • 1269 Answers
SOURCE: My phone does not connect
Hi!
If it was working before, you only need to clear or delete the current wifi profile on your phone for the netgear router and just create a new wifi profile. Make sure to enter the corrent Wireless Settings specially the Security Key. It is case sensitive, sometimes that's the only problem why you cannot connect. You are typing an incorrect network key. You can also try to change the channel that the netgear is using. Power cycle can help you also. Just unplug the power on the back of your router for 30 seconds then try again.
Posted on Feb 14, 2011
  • 184 Answers
SOURCE: I was able to connect
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Posted on Sep 25, 2011
How do I change the Password on my Netgear AC1900 Smart WiFi Router
If you do not know the password and are wanting to reset to out of the box settings
Power on the Router
wait several seconds
Hold down Reset for 5 to max 8 seconds ! **
connect to 192.168.1.1
flash the initial FW
now the Router reboots
** After every reset, the first login screen on StockFW should show something like "refreshing settings or loading settings"
Now its like Out of the Box.
Nov 13, 2016 | NetGear Computers & Internet
How come my NetGearWNDR3400v2 N600 won't connect to my smart phone
May be problem with your smart phone try to connect other phone
Mar 01, 2016 | NetGear Computers & Internet
How to connect to DG834PN
It's fairly straightforward. It connects to your WiFi as a wireless client. You can then connect wired network devices to it instead of needing to run a cable to the WiFi router.
Aug 09, 2014 | NetGear WNCE3001 Universal Dual Band...
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
Problems with WiFi netgear WNDA3100
the drivers should be installed in windows 7 by default, their so called "smart wizard" has some compatibility issues with windows 7, I get it to load up and it will shut down or glitch out. What I did was uninstall the downloaded driver and use the default windows drivers, flipped the switch off to my built in G wifi adapter and the netgear automatically kicked in and took over as the default wireless adapter.
Nov 06, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
HP 6710b , wifi activate button not work...no light on
click the link here, and confirm it helped you solve the wi-fi problem on your laptop, if not then i'll provide another workaround.
Sep 21, 2008 | HP Smart Buy Notebook
HELP IS SOMEONE USING MY WIFI CONNECTION
Nov 24, 2007 | Computers & Internet
Open Questions:
Netgear Wireless Router @&@(1-84433O233O)tech Support Number Usa Contact Help Desk Phone Number Netgear Router Tech Support Number 1(844)33O-233O is an independently owned and operated all kind of technical support. There are a long series of Netgear Router Wireless including latest technology and affordable price. Netgear produce All-In-One Router with basic printinG copying and scanning functions. Netgear Routers are compact and lightweight.Netgear Router Tech Support Number 1(844)33O-233O is an independently owned and operated all kind of technical support. There are a long series of Netgear Router Wireless including latest technology and affordable price. Netgear produce All-In-One Router with basic printinG copying and scanning functions. Netgear Routers are compact and lightweight.Netgear Router Tech Support Number 1(844)33O-233O is an independently owned and operated all kind of technical support. There are a long series of Netgear Router Wireless including latest technology and affordable price. Netgear produce All-In-One Router with basic printinG copying and scanning functions. Netgear Routers are compact and lightweight.Netgear Router Tech Support Number 1(844)33O-233O is an independently owned and operated all kind of technical support. There are a long series of Netgear Router Wireless including latest technology and affordable price. Netgear produce All-In-One Router with basic printinG copying and scanning functions. Netgear Routers are compact and lightweight.
Jul 22, 2019 | NetGear Computers & Internet
Computers & Internet Logo
257 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
