Question about MSI RC410M-L Motherboard
Hello. My Maxdata with the RC 410M is almost dead. Both power supply fan and processor fans are working but that's it, nothing else will work. It wont even boot from the recovery disk that is now stuck in the dvd drive. Any ideas good people?
    Problem Solver:
  • 15 Answers
Sounds like your board is not getting enough power to get everything up and running. Attempt changing the Power supply with another and try, if not, then your board probably had gone bad
Posted on Aug 03, 2009
Hello, my system has Asrock P4I45GV Motherboard.
your possessor fan dos not properly work or fan casein do not properly instal or your power supply faulty.
Sep 04, 2013 | Asrock P4I45GV R5 Motherboard
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
Thanks to Krishmaqvan, but the problem is the pc
complete dead system first see the power supply if it works fine go to mother board and check if any cable has removed before if not take out the processor fan and power on and put your thumb in processor it will be hot if mother board is working any information email me zaal_721@hotmail.com &nbsp; <br>
Aug 29, 2010 | Soyo P4X400 Dragon Ultra Motherboard
I had a loud fan noise coming from inside my desktop box for a while. One day (& ever since,) when I went to turn the box on, absolutely nothing happened: no fans, no BIOS, no LEDs. I made no config...
This may work however i think by ignoring the sound of the Fan you might have destroyed the cpu and the motherboard.If you can try the processor in another machine you might just have to replace the motherboard only.
Good Luck
Dec 03, 2009 | Intel Motherboard
COMP. JUST CUTS OFF AND EVERYTHING GOES DEAD. BLUE LIGHT BLINKS BUT WONT WORK TILL YOU TOTALLY DISCONNECT AND PLUG IN AFTER 20 MIN. T6528
Power Supply is the highly probable culprit on this. Call your local manufacturer to replace the power supply. Also, try connecting it directly to the power outlet (if it's connected to a power strip). Also, check the fans on the computer. All should be spinning and air should be coming out of it. Feel the air coming out, is it warm or hot. If it's hot then I suggest you really call your computer manufacturer or who you got this from since this needs more troubleshooting and probable replacement of parts inside.
Nov 08, 2009 | E-Machines eMachines Desktop PC
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
My laptop will not powerup .....
so does the laptop turn on at all with just the battery in. or is the battery got a charge
Apr 15, 2009 | Acer Extensa 5420-5687 Notebook
HP Pavilion a1150y fans run when powered on but windows doesn't load, monitor, mouse and keyboard do not work. (Running Windows XP)
Believe it or not, it's due to a weak power supply. More specifically, weak voltage rail/s caused by failing Electrolytic Capacitors.
A bad computer power supply is about 70% of computer failure.
ALL the light use less than 1 Watt. EACH fan uses 2 to 3 Watts.
A processor uses 55 to 125 Watts. Depends on the make and model.
Since the power supply is weak, it doesn't have enough power to turn the processor on.
No processor, nothing to find the Boot record on the harddrive. Nothing to get the Operating System going. (Example: Windows XP)
No computer running, there is no signal to the monitor.
Just enough power to light lights, and spin fans.
Apr 13, 2009 | HP Computers & Internet
Laptop does not power on !
first of all change ac cord and batter then try with the fan
May 16, 2008 | Acer Aspire 3004WLCi Notebook
MSI RC410M-L Motherboard Logo
178 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
