Question about Nokia 3230 Cellular Phone
I have nokia 3230 when i switch on, only gray screen appears then after that it turns to black and white horizontal line..i tried to reformat my phone using *,3 and green button then switch on but it doesn't work only gray screen appear..pls email your reply in sylvaniagie@yahoo.com..pls help me to fix my phone..i can't use my phone now..pls reply as soon as possible..tnx a lot..
  • eugie Aug 03, 2009
    i tried it before but it doesnt work... only gray screen appear, i cant use my phone coz there is no images appear...pls help me..tnx for your reply..pls give me another tricks to fix my phone...pls reply as soon as possible...tnx a lot...
    President:
  • 1,884 Answers
The code for formatting the nokia phones is *#7370#. Have you tried it. And before you do that press the power switch enough to give you a list of profiles. Select General profile. and then format your phone.
Posted on Aug 02, 2009
  • Vinay Tevatia
    Vinay Tevatia Aug 03, 2009
    Then updating the firmware is the only answer. Select the General profile and connect to the PC connected to the net. Update the firmware thru Nokia SW Updater that can be downloaded from Nokia site. Alternatively, visit the nearest Nokia Care and get it done thru them. Does not take more than half hour as they do it with their PC and do not use the net. Much safer.
Nokkia 5130 -screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off...
nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
Sep 22, 2011 | Nokia 5130 Cellular Phone
See White Screen + Nokia Logo + Failed to Start contact Retailer
Try formatting your phone and see if it works.
First make sure your phone is turned off.Then press the following buttons simultaneously (at the same time:
Power button + * + 3
This will restore and reformat your phone into factory settings. Hopefully your phone will be able to start again as if it were being used the first time from the box.
Let me know if it works,
Hope I have been of assistance to you,
Cheers :)
Sep 03, 2009 | Nokia 3230
NOKIA 3230 - 'Switch on' problem Hi, My nokia 3230 mobile got switched off on its own and I am unable to switch it on since few days. Even the logo "Nokia" is not appearing on switching the power switch....
Hi ,Try to charge your mobile with another same model battery, switch it on.. and keep it swiching on for five mins,, and try with your battery .. its really works.. this is all because your battery charge limit is gone under minimum
May 30, 2009 | Nokia 3230 Cellular Phone
Hi Friend,
Initially u have remove the sim card and the battery.
Once u have removed insert only the battery and put to charge for 10 to 15 mins.
then remove the mobile from charger and insert the sim card.
Now after 30 sec switch it on.U will be able to do the process
Regards,
Ayyasam
May 29, 2009 | Nokia 3230 Cellular Phone
Problem with the screen
it might be your verison, try update-ing it or you may have to get it checked out, you can update it by slecting your phone and downloading the software: www.nokia.co.uk, or just go to your local repair centre and find out the problem
Apr 25, 2009 | Nokia 3230
Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Aug 28, 2008 | Nokia 7610
Nokia 3230 startup failed
TRY THIS MANUAL FORMAT:
JUST PRESS KEYS *,3 ,call ..While pressing, turn on
the power swicth until formating appears on the screen.
Then just follow for further instructions.. Thank you much!
You can send me email for further results at st_nardz@yahoo.com
Kindly rate this soluton!
rg_nardz
Aug 09, 2008 | Nokia 3230
Power on/off problem
3230 try another battery
Dec 18, 2007 | Computers & Internet
Nokia 3230 Cellular Phone Logo
160 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
