Question about Samsung Refrigerators
WE have a Samsung fridge freezer model RT21MH. The unit works well but the plastic shelving for the door and vegetable compartment need replacing. Where can we buy replacement parts? We live close to Vientiane in Laos.
zeusfaber
  • 247 Answers
SOURCE: fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
Posted on May 16, 2007
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
  • 56 Answers
SOURCE: Need two door shelves, Sub Zero, 251 RFD, the last two shelves
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code will get you to the nearest SZ?wolf parts distributor.
Posted on Apr 23, 2009
co7196
  • 3433 Answers
SOURCE: the fridge on my bosch fridge/freezer keeps freezing all my food
This, as with the on off complaint on a bosch, sounds like your thermostat is n't paying attention. Turn it up, then slowly down and feel for any irregularity. If there is looseness or rough, like hsngin up its the thermostat. At least we know the bulb goes out when you close the door. Good Luck
Posted on May 25, 2009
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
How do you know your Bosch Fridge Freezer needs defrosting?
Most home refrigerators share the same cooling coil for both compartments so in order to defrost the freezer that coil has to be disabled by pulling the plug. You havent mentioned the brand of refrigerator that you own but i am guessing that you have an automatic defrost. Can you hear a fan running inside the freezer compartment when the door is closed and the compressor in the back is running? If so your freezer will automatically defrost. The ice you probably see collects on the shelving or inside walls. Generally you can take the plastic handle of a screwdriver and gently tap the ice to get it to crack and fall off. Take care not to hit cold plastic parts or panels, they may crack or break. Otherwise I would get the model of the refrigerator and go to the manufacturers web site and post your question to get a positive answer. Good luck!
Jun 02, 2012 | Bosch Freezers
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Hi i have model sb540w and the fridge doesnt get cold enough but the freezer is fine called an engenier and he did not understand wat the probs was as the fan works at the back.
Your unit has one condensor unit, so if the freezer side is freezing, then the problem has to be in the freezer section.
First check to make sure that the fan is operating in the unit. If it isn't then it is probably the fan, BUT maybe not bad so hold off replaceing it. If the fan is working then you probably, have a defrost problem - when the defrost assembly stops working ice build up behind the rear panel in the freezer compartment so the thermostat gets a false reading and won't send tell the fan to kick on to send cold air to the refrigerator section.
So you will need to take the food out of the freezer, remove the shelves, remove the inner rear panel in the freezer compartment and look for ice build up. If you find it, then you can either unplug and leave the door open to defrost or use a hair dryer to hurry the defrost up - DON'T USE HOT WATER!
Once defrosted, you can dry the unit out and then turn it back on, use your make and model number to order the defrost assembly, but you can use your refrigerator and freezer until it arrives.
Jun 07, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
How can I access the defrost heater on maytag model rtd21a freezer/ref? I see only one screw in the freezer compartment. I have replaced defrost heaters in whirpool and kenmore. There are screws in those...
The defrost heater sits behind the evaporator coil. The evaporator coil lies horizontally between the freezer and refrigerator compartments. It is a lot of work to get access to the defrost heater. To do that you will need to remove the shelving in the freezer, both the refrigerator and the freezer doors and the trim pieces between the freezer and refrigerator compartments and remove the plastic liner at the bottom of the freezer. Once you removed the plastic liner, then you can see the evap coil and the heater is way in the back of the coil. Good luck.
Jul 01, 2010 | Refrigerators
Freezing food in Frig especially lower compartments
Is you refrig. cycling off and on?... sounds like a themostate if its NOT.. you might see if you have vents that have adjustments.. pull out the crispers and check for adjustable vents ... if there close them down some.
Aug 30, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge bottom has water under vegetable drawers
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
74 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
