Question about Kenwood KDC-W7027 CD Player
How can i fix it
The front panel on my kdc-w7027 radio was forced down when the power was turned off, the radio still works but the panel will not fold up when the radio is turned off, i would appreciate it if you could tell me how to fix it.
Thank you
Tommy
    Problem Solver:
You need a part cog just replacing one at the moment but remember the position it was in or it wont work when reassembled. cog is only nilon probably threaded. take off top, one screw. take out cd plater two silver screws either side on front. carefull when disconnecting ribbon under neith push up brown clip either side then prise out ribbon. now with great care unscrew two brassy collered screws on black metal cover to right hand side also a black screw on the side. you will have to move the screen in and out when doing this use the white cog to you right on top roll it backwards and forwards.now you will see the mechanisim for the front panel you will see from there whats threaded. probbably the little clear white cog sideways on on the right.
hope this helps.
mike.
Posted on Dec 24, 2009
E05 error kenwood kdc-w7027
Sounds like your laser is dirty or faulty. Try a cleaning CD.
Dec 10, 2013 | Computers & Internet
Kenwood KDC-W7027 will not go home all the way
Chances are, there is either a bad gear or a bad position sensor lever. More than likely it will be the lever. Both parts are inside of the deck itself
Dec 11, 2012 | Kenwood KDC-W7027 CD Player
KDC-7027 car sterio comes on for a second then moves then goes off again
sound like you have a bad ground. pull the stereo out and check your ground wire go from there.
Jan 11, 2011 | Kenwood KDC-W7027 CD Player
Radio Unlock Code and How to force eject CD without power?
All coded radios are made from both the serial and Vin#
contact the vehicle distributor to get the code generated
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Car Audio & Video
I just bought a car that has a kdc 516s and
You need to flip the front panel down first and there will be an eject button on the inside of the panel. If this is not working try pressing the tiny reset button which is left of the ATT button.
Dan
Nov 18, 2009 | Kenwood KDC-516S CD Player
How to put the code in my cd radio
SELECT THE SECURITY DIGITS TO ENTER PRESS THE FM OR AM BUTTONS PRESS THE [[ ]] ARROW SEARCH BUTTONS TO MOVE ALONG AS YOU ENTER YOUR CODE WHEN CODE IS ENTERED PRESS AND HOLD ]] FORWARD SEARCH BUTTON FOR 3 SECONDS RE-ENTER MAY APPEAR REPEAT THE SAME AS ABOVE TO COMFIRM CODE IF NESSARY HOPE THIS HELPS YOU JAKE YOU CAN DOWN LOAD A MANUAL FREE I HAVE ENCLOSED MY MOBILE NO 07936635539
Jun 07, 2008 | Kenwood Car Audio & Video
Kenwood kdc 7027
The home position switch from the angle of the front display is not pushed correctly. the problem is mechanical.
If you glue a little tip of plastic between the actuator and the homeposition switch, your problem is history.
In my case, a tip of a little tiewrap did it.
Feb 20, 2008 | Kenwood KDC-W7027 CD Player
"WAITING 3"DISPLAYED
KENWOOD SECURITY CODE CLEAR procedure Your radio will require one of the following procedures. Type 1 During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that ??? disappears). Then using your remote enter your code. Type 2 Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear". Then using your remote enter your code. Type 3 Model# DPX-4020 and DPX-4030 Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display. Then using your remote, enter your code. Enter your number from the remote control unit. Your code number is 5227 (KCAR) * Press numeric key ?5? ( 2 times ) and press the Track UP/Next Track key * Press numeric key ?2? ( 3 times ) and press the Track UP/Next Track key * Press numeric key ?2? ( 1 time ) and press the Track UP/Next Track key * Press numeric key ?7? ( 2 times ) and press the Track UP/Next Track key The security is canceled and the set enters the TUNER mode! Luck
Nov 20, 2006 | Kenwood KDC-W7027 CD Player
Kenwood KDC-W7027 CD Player Logo
131 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
