Question about Orange Crush 30R Reverb Guitar Amplifier
Handmade guitar amp, when i plugin the guitar i start playing, but then signal gets lost, the sound dissapears, and then it appears again, and after minute or two it dissapears. i've tried to put full volume and it worked few times, but the last time i tried it didn't work. please can anybody help me? thanks
  • goran_vedris Aug 04, 2009
    ok. thank you very much
  • 313 Answers
Have you got valves fitted to the amp as they can cause fading if old >damaged >not fittted properly also check the speaker connects and try playing half volume the output should be steady.. you say its handmade if you made it pull out the amp board and check your soldering joints look to see fi there is any that need resoldering as they may be getting hot and causing a resistor to fade..
Posted on Aug 04, 2009
Value of a alvarez yairi 1978 mod dy55
I have a few questions before trying to be precise-Is this supposed to have been handmade by Kauzo Yairi?.Do you have a pic of the guitar?.I got a guitar around '1966-handmade
with the writing inside saying something like this-CBS Masterworks handmade by K Yairi ser #... i eventually settled on a price between $5- and $ 7000.00 CDN.That was through an insurance co about a year ago.
Feb 02, 2017 | Alvarez Music
While playing through this amp I stepped on the channel changing footswitch and lost all sound from amp. all tubes and pilot light remained on but amp went silent. Disconnecting footswitch and cable f
Plug the guitar on the "power amp in" jack near the "presence" knob.
If you get sound, you have a problem on the preamp. If not, it´s probably on the power amp section.
Its a good start...
Dec 23, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Warwick xtreme bass amp no sound
get a new amp or try buying a new guitar i do not no ask the people
at gutair store sorry if i can not help
Mar 24, 2014 | Warwick Music Equipment Warwick XTreme 51...
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Only just bought amp ,but twice now its just cut out,lost sound ,if i switch off wait a minute it ciomes back on cannot be normal surely? rgds neil
Not normal... however verify your guitar cable and guitar to avoid embarassment if the problem might be with those items. ALSO if you are driving this too hard, it probably has thermal shutdown and will shut down the power amp if the circuits get too hot... This is a smaller amp so If you are playing louder than *********** could stand it in a 15 foot square room, you are overdriving this unit and you best get a bigger one.
Aug 07, 2011 | Marshall Amplification *new* Marshall...
FM 65R plays and sounds great for about 5- 10 minutes then it sounds weak and distorted. If I play directly into the power amp input it sounds great again just no control for the volume and tone.
Also the volume will probably be lower going into the line level PA input... If the amp is shutting down for thermal reasons, driving it less might not get to the point of shutdown. The schematic shows a temp sensor that reduces and shuts down the amp if the heatsinks get to hot. Possibly you are driving the amp harder than it is intended, If it is as loud (I doubt it) driving the PA input, then I would expect it to shutdown, but you would probably have to drive it harder than your guitar because guitar levels are well below line level. The amp claims 65 watts... don't believe everything you read in spec sheets... You should be able to generate 100 Db of sound with it... The more distortion you use will drive the amp harder and heat the heatsinks faster.
May 13, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Hi, My Aria AS-690B Sinsonido has started making a strange crackling / low grumbling noise when plugged in. It still plays well, but the noise gets very much in the way. It sounds electronic. Any ideas...
First thing is to check that batteries are good. Next, verify your guitar cable is a good one... some are microphonic and the cable can actually insert noise into the signal. The plugs on cables can sometimes be noisy as they move while playing. Try to keep the guitar from "hearing" the amp as it can create feedback. Verify the amp itself isn't the source of the noise. Try a different guitar. The input of the amp is grounded by a contact when cable is removed, If there is a problem right in the input stage it can be masked. Plug only the guitar cable into the amp... Is ti quiet? If so make sure to try the first few suggestions. ALso be aware of other noise producers like fluorescent lights an dimmers... these generate electrical noise that sensitive guitars can pick up.
Apr 14, 2011 | Aria Sinsonido AS-100C
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
Orange Crush 30R Reverb Guitar Amplifier Logo
136 people viewed this question
Top Orange Music Experts
Michial Gueffroy
Are you an Orange Music Expert? Answer questions, earn points and help others
