Question about Lite On LVW-5005X DVD Recorder
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
It plays the disc in the tray and also plays and records from/to hard drive from the TV but won't open the disc tray.
  • Carole Iverson Aug 02, 2009
    When I press open/close I hear a clunk like it's trying to open, then a couple of seconds later a second clunk and then nothing.
    Problem Solver:
  • 16 Answers
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Posted on Aug 09, 2009
  • 3 more comments
  • kgburgess Dec 10, 2010
    I tried this method, but mine still won't open. I've recorded and formatted a disc, but I can't get the tray to open to release the disc. Any other suggestions?
  • Eric Andersen Dec 11, 2010
    Are you sure you knocked on the TOP of cabinet just above the disc tray door,once again you must push the open button at the same time.90 % of the time it will open.
    Tray doors won't open for three reasons a bad belt, tray misalignment, the third being jammed gears.The most common is a bad belt.Have you had trouble with the door before?When you try what I said, does it attempt to open?
    If you have hit the tray with your hand in the past you may of thrown it out of alignment. If belt is a little loose from age or it the tray is out of alignment a wee bit it usually will open by this tapping on the cabinet.If the belt is broken or tray is way out of alignment or if the gear inside the burner is jammed you can only open door by opening cabinet,if the gear is jammed it is best to replace the entire loader/burner.This is best left to a professional. WARNING :NEVER OPEN CABINET WHILE PLUGGED IN you could suffer electrical shock or laser burns.Even if unplugged never touch the power supply with anything metal,sometimes it will still have an electrical charge in it.
    Some people have removed the disc tray cover if it keeps sticking repeatedly because of alignment problems but of course to this you have to have the disc tray open.If you are lucky enough to get it open you will see the little black belt that operates pulley,it is size 1.9.If you get it open and want to remove disc tray cover press open and pull electrical plug in the open position so the door won't close,then grap the tray with one hand securely(so as to not effect alignment)with your other hand grap disc tray cover and twist upward.This little cover snaps on and off.There are two hidden adustment screws behind this little cover.To adjust turn each screw only a quarter turn and snap back on a try it.You might have to try this several times to get it just right.
    DIsc tray sticking is very common on some of these older Liteon models.Fortunately they have had very few problems with the hard drive.In fact your model is kind rare and is worth fixing.
  • kgburgess Dec 11, 2010
    I actually tried lots of suggestions I found posted on various models (mine is an LVW-5005X, with firmware altered to be an ILO). None of them worked. I did open up the case and took the cover off the top of the drive. I did find the little sticky gasket in the middle, which had almost glued itself to my disc. So I manually removed my disc and rubbed baby powder on the gasket to cancel out the stickiness. Another reviewer mentioned this problem. I thought that would fix it, but it still wouldn't open when I reassembled it. Then another reviewer mentioned with this particular model that sometimes you have to lean the console forward and tip it downward while pressing eject. I did this, and at first it didn't work, so then I repeated it while tapping on the BACK of the console, and it opened! I grabbed the tray quickly, as it tried to go back in. Then it kept opening and closing by itself. I turned it off and back on again. Then it worked like a charm after that! No more sticking. So glad to have it working again. Thanks for your help!
    Sticking tray door is common with this model.If the door doesn't want to open you need to replace that tiny black belt this opens and closes the door,they stretch as they get older,use a twizzers to remove and replace.It is called a square belt,the size is 1.9.If a tray opens and closes it means the tray door is NOT closing all the way,so you need to adjust the tray door.I mentioned how to do this under the 5045 model.Some people have removed the tray door all together.An alternative is replace the stock loader/ burner with a PC burner,these last longer and the dist tray door is gear opened, it uses no belt.
  • dirtstiffone
    dirtstiffone Nov 12, 2012
    How do you get the dvd out of the unit ,does the face plate have to come off to
Dvr drive tray will not open
In the cover of the tray, look for a small hole the size of a pencil lead. Get a paper clip, straighten it out and push it into the hole. That should release the tray so you can get the disc out.
Jan 20, 2018 | Philips Dvdr615 Dvd Recorder
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
All of my clean games that i put in dont work why
to solve this problem, you need to take out the hard drive. the ps3 hard dirve can be hot after you play games for a while. the DVD ROM probably won't function when the hard drive is over heated. the hard drive should be put in cool place. you should let the hard drive remain in a cool spot temporarily. the place where you put the hard drive should not be exposed in direct sunlight. you can open window and let the air come in while playing. you can switch on the fan and turn it against the hard drive. in this way, the heat in the hard drive will quickly dissipate away.
sometimes, the DVD ROM is not functioning properly because of loose cables. checked the cables to see if they plugged in properly. you can plug out the cables and replug them. after replugging them, you can turn on your console to see if it's working again. just make sure that the disc tray isn't overly dirty or filled with dust, this can cause the reader to not work. always wipe the disc tray and the disc that you're using before playing.
if this didn't work, you have to send it to sony. you have to pay delivery cost and repair cost. if it's still under warranty, you only have to pay the delivery cost.
thank you for choosing fixya.
Dec 03, 2011 | Nintendo Wii Console
Ps3 wont read any disk I replaced the drive and still wont work, what could be wrong
Dec 02, 2011 | Sony Playstation 3 (PS3) Console
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
When I power up my LG RHT397H the DVD tray opens, it will not accept any discs. If I press CLOSE the tray closes then re-opens. The fault only affects the DVD drive - the unit records on the hard disk, and...
Sounds like possibly the Spin Motor is bad and not spinning up the disc's. That's usually what I've found, if it were the optics assembly, it would take a long time before it finally gives up and say's something like "No Disc", "Disc Err", etc.
Jun 12, 2010 | Televison & Video
How can I play a Region 1 Dvd in Australia?
power on the tv and dvd without any dvd in tray
open disc tray
press pause then 0000000 on remote
region menu shows on tv screen
select ur region
press pause on remote
then power off
Jan 26, 2010 | LG RH177 DVD Recorder/HDD Recorder
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
Nov 18, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
Lite On LVW-5005X DVD Recorder Logo
1,693 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
