Question about Garden
My flymo ht600 is just blowing air! It cut one piece of hedge and now is just blowing air.
2 Suggested Answers
ianharper74
  • 5 Answers
SOURCE: flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Posted on Sep 09, 2011
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
My flymo sabre cut keeps cuttn out every time the cord moves
Apparently you have some wiring issues ,that can be caused by the cord being stretched away from the handle...it can be rewired near the handle by someone with electrical knowledge,,,,,,must be familiar with electicity because of the power going into it by a home source and the hazzard of using it in damp or moist grass. shock hazzard
Jun 09, 2012 | Garden
I have a Flymo Sabre cordless hedgetrimmer, which has stopped cutting anything although the blades still move. What can I do to fix it?
If there are screws or bolts holding the blades together, check these are tight, but not tight enough that the blades can't move relative to each other. If the teeth aren't sharp, you can buy a small flat file to sharpen them. This is a tedious process and both cutting edges of each tooth need to be sharpened.
May 11, 2011 | Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Flymo sabre hedge trimmer blades move but do not cut!
Jul 23, 2010 | Garden
I have a flymo easi-trim electric hedge cutter that has not been used very much. When went to use it gave a loud high pitch squeel, this happened a couple of times before it started-up. But then it would...
when u say not been used verry much do ya mean it's possible it sat long enough for a mouse or two to make a nest inside the motor? LOL.
seriously tho it sound's to me like the motor just burned out. Personally I would recommend investing in a gas powered hedge trimmer. they last longer and do the job better plus there's no chance of accidently cutting through the extention cord.
Nov 05, 2009 | Garden
My flymo hedge trimer is working but not cutting it is a eseicut 510
Probably need to sharpen the blades. Take it to a repair shop around town and they will sharpen the blades for you...............
Sep 20, 2009 | Heavy Machinery
Intimitant Fault
Hi !
I can help you with the manual!
http://www.flymo.co.uk/node789.aspx
Go to that site, in the window obove the "search" type HT450
Now you will see all avalible manuals for your hedge trimmer, and there are a couple of them. The manuals are in PDF so you can either download them or read them on your screen
Good luck¨
Nci
Apr 22, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
