SOURCE: just received my tascam DP02..manual
The song you have selected, the demo is protected, try anoter file.
SOURCE: TASCAM DP02 CF
Try a seperate mike pre-amp, solved my problem. The output of both my dynamic and condenser mikes was too weak for the built-in pre amps in the DP02. Seperate pre-amps are also quieter than the DP pre-amps Turn the seperate pre-amps up first, then use minimal DP02 pre-amp. Good luck
SOURCE: No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
SOURCE: tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
SOURCE: Tascam 424 MK II, how to bounce tracks?
Here is a link I found that took me to an owners manual for your device.
http://www.scribd.com/doc/264105/TASCAM-424-mkII-Manual
Hope this helps :D
