Question about Sony VAIO VGN-FJ270/B Notebook
Sony vaio VGN FS 742W notebook Startup problem.When swithed ON,Vaio,Window XP screen appears and then window 'isass' appears & notebook swithes OFF automatically.Pl.advise solution for the above. Thanks Pradip Chembur Mumbai
  • Sony Master
  • 19,396 Answers
If Windows appears, and start booting, then the problem concerns the operative system and not the hardware.
That is good news, because all you need to do is using the original computer recovery disk, or finding a Windows setup disk to reinstall Windows.
To reinstall Windows, start the computer with the Recovery Disk or Windows Disk inside and chose Boot from CD when asked, then follow instructions.
Regards.
Posted on Aug 02, 2009
Factory settings sony vgn-n31z/w
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
or
Sony Vaio usually installs their system files right on the computer.
If you click on "Start" then "Vaio Central" a window should open up.
Click on the "Support" tab, then "Recovery".
hope this helps
Oct 03, 2012 | Sony Vaio VGN-N31Z/W
After xp installation my sony vaio vgn-sz2xp display did not appearfully.black spaces are appeared on the both side of the screen......... kindly help me its too urjent
I would guess that the video driver has not been installed? If it has, try changing the display resolution to see if it will fill the screen.
You can obtain driver software for this machine at the following URL:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-SZ2XP_C
Jul 22, 2011 | Sony VAIO® VGN-SZ2XP PC Notebook
Vaio sat survey not working
The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
Please follow the below steps to disable the Application from starting automatically and fix the error message.
  1. Open the run window by pressing the "Windows" and the "R" Keys.
  2. Then, in the run window, please type "msconfig".
  3. This will open the "System Configuration Utility" window.
  4. In the System Configuration Utility window, please click the "Startup" tab.
  5. In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
  6. Then, please remove the check mark next to the above items.
  7. Then, please click the "Apply" and "OK" buttons.
  8. The Computer will prompt to restart.
  9. Please restart the Computer.
  10. The error message should not be there when you restart the Computer.
Jul 27, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Screen has been switched off...how to swith on the
try pressing FN and F6 together while laptop starts up or contact the manafacturer for guidance
Mar 11, 2010 | Sony VAIO VGN-NS140E/S Notebook PC
L have lost all factory programs inc webcam can i download these
You can download drivers from the Sony WEB site.
Select your model notebook and the Windows XP or Vista drivers you require. Use this link.
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
Dec 17, 2009 | Sony VAIO VGN-FE880E/H Notebook
How to insall keyboard on sony vaio fs 635b
Here is the link to your service manual, the keyboard removal procedure starts on page 7. It is in full color pictures and detailed.
http://tim.id.au/laptops/sony/vgn-fs.pdf
Dec 08, 2009 | Sony VAIO Notebook
I have a Sony vaio vgn fs 742/w notebook which has startup problem.When switched ON -Vaio &subsiquently Window XP appears
I did not understand real problem Please make more specific for the problem. what happens Win XP appears? then stays rigth there? Does not boot? Thank you
JMC
Aug 04, 2009 | Sony VAIO VGN-FS742/W Notebook
My VGN FS920 shuts down at the window loading screen
ok no need to get a bcakup disk or downlaod anything
if ur hard drive is original factory fitted
and
ur laptop came with pre loaded OS as XP
then do this without disk
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
pls let me know and rate me FIXYA for help
Mar 31, 2009 | Sony VAIO VGN-FS920 Notebook
Sony VAIO VGN-FJ270/B Notebook Logo
250 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
