Question about AEG Washing Machines
LAVAMAT MOTOR DOES NOT RUN
INTERMITTENTLY, Lavamat 6050 MOTOR DOES NOT RUN
  • AEG Master
  • 19,396 Answers
If there is water getting into the machine, then the motor, motor control unit, pressure switch, timer control and wiring harness must be tested. If the machine is a top load the motor coupler may replace the MCU of variable speed motors, that must also be tested then.
If cycle is not operating at all, with no water getting through the inlet check lid switch, door latch, inlet hose , inlet valve, membrane switch, Timer board and MCU if present.
Posted on Aug 02, 2009
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
CANON 6050 E010, E002
E010 is a problem with the main motor. replace motor
E002 over heating replce thermistor
Dec 25, 2010 | Canon NP 6050 Copier
CANON NP 6050 ERROR CODE I55 PLEASE HELP MY PROBLEM NOW
check the lens motor maybe the gear of lens motor is broken
Dec 05, 2010 | Canon NP 6050 Copier
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
My AEG Lavamat W 1000 runs properly but won't spin
a little late to solve your problem...if it ever happens again, change the 16 micro farrad capacitor in the upper rear right corner of the machine. This capacitor controls the starting torque in any motor mode
May 15, 2010 | AEG Lavamat W1450 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
182 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
