Question about Bose Lifestyle SA-2 2-Channel Amplifier
Bose terminal block connector
where can I get a BOSE 4-pin terminal block connector for a BOSE amplifier SA-2?
Many thanks in advance
Steffen
    Sergeant:
  • 263 Answers
Http://www.4electronicwarehouse.com/products/bose/ta2-adapter.html
Posted on Aug 02, 2009
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
Splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
Nov 27, 2011 | Bose Cinemate Digital Home Theater System...
Bose SA-3 amp and a non bose sub.. I keep blowing the amp..
How many ohms is your sub? The SA 3 Amp can only handle speaker(s) 6 ohms and greater. A lot of subs, as I understand, are 2 and 4 ohms typically. If yours is 2 or 4 ohms, then that explains it. The speaker would be "straining" your amplifier and blowing it.
Oct 02, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
How to start a Bose acoustimass 9 powered subwoofer
The Bose cube systems are SYTEMS for a very good reason. They're made for people who want good sound but don't want to manipulate the hardware much. The speakers and amps are designed for each other ONLY, not only electrically but through soundshaping to provide the smooth final result. The design is for you to feed the electronics a Line Level source and the magic and distribution happens internally. These are NOT mix 'n' match components. The special connectors are a clue. The 'different' amplifier will probably blow them up.
Mar 31, 2009 | Bose Wave Radio
Best way to use US-Bose SA3 amp in Europe ?
Bose say you should pay to get it converted because over time the slightly different power cycles can effect it, however it will still works fine if you change the voltage with an adapter - like I did!!!
Dec 12, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose speaker 151
Hi
I checked in the specs of the manual here. page 6. They quote it as being suitable for 4-8 ohm AMPLIFIERS. but do not mention the actual impedance. I would expect from that that the speakers must be close to 8 ohms, as you they would not advise you to connect a 4 ohm speaker to an 8 ohm output stage, as likely damage could result. If you had a multi meter, you could do a DC resistance check of the speaker, this is generally very close to the impedance. happy to talk to you more about it.
regards
robotek
Nov 04, 2008 | Bose Lifestyle SA-2 2-Channel Amplifier
Bac speaker bose 321
The arrays from this system are only designed to run with the Bose Acoustimass / subwoofer, which in turn will only work with the Bose DVD player. If you use them directly to an amplifier, they'll sound poor / wierd and you probably blow the drivers. You might even damage your amp.
Each speaker has 2 drivers firing in slightly different directions. The idea is (when its used with the 321 system), the inward speakers give a mix of front and centre, the outer drivers give a mix of front and rear. A normal amp won't do this....
Nov 28, 2007 | Bose 3·2·1 II System
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose Lifestyle SA-2 2-Channel Amplifier Logo
1,584 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
